HI…
i am working with M1306B modem…actually everything is working properly means…
i get connected to gprs,connection starts,i get an remote IP adress but what to do after the???/
means which cammands i need to send to acsess web?after getting connected??
plz help me
are you using at commands? or open at application?
if you use at commands (and yout have wip stack) you can use the at+wipcreate to connect to a server
and the at+wipdata to enter data session
after that whatever you type is sent to the server
you must usee the GET command, i don’t know much about it, it is a http command, after usint it correctly the server will sent to you the html code of the page you have requested with the get command
HTTP Made Really Easy: jmarshall.com/easy/http/
Also read the section on the WIP HTTP Client in the WIP Manual, and see the example in the examples section…
