Hi
I am attempting to use MS Visual Studio 2005 (express) instead of eclipse (because I don’t think eclipse is working properly yet).
After a bit of messing about (using tips from this forum) everything works except for the generation of .wks files (in fact any build info for TMT).
I get the following warning during an RTE build (which I guess is the cause of the issue)
Any ideas?
awneil
2
No, that’s not the cause - I get exactly the same with Visual Studio 2003.
This is a bug introduced in the Wavecom build system for v3.12
ooh
Any other ideas for a solution?
Cheers
John
For information - I found that everything worked following a re-install of OAT 4-24
Cheers
John
Hi, to run your project in visual studio 2003/2005 you need to select “wismo target”. By default, visual studio selects Debug.
awneil
6
No, that is not true - certainly not for VS 2003.
That is true - but the Debug target works fine for me!
