OK, done a bit of digging and the problem seems to lie in the [b]OpenAT[/b][b]\OS[/b]<os-version\bin\export.def file:
If I remove the OATAPP, the project builds cleanly with no warnings - but I haven’t tested yet to see if it works OK…
From the VS online help, it seems resonable to remove it, as the Library name is already being specified elsewhere - which is the cause of the warning!
The linker says, it ignores the directive, so it should not cause a problem if you remove it. Yes, the libary name is already specified in the “properties->linker->general” settings and the two are not the same that causes the warning. It is strange, that it has been unnoticed so far.
