MQTT client implementation on RV50X
I need to implement a MQTT client on a RV50X able to handle Qos level 1
I have read the example detailed here : https://source.sierrawireless.com/airvantage/avc/howto/hardware/samples/gx440-mqtt-lua/
but apparently , this client is only able to handle qos level 0. Is that right ?
Has anybody experimented other clients implementation , able to deal with qos level 1 ?
I found several lua implementations of lua clients :
would they work on RV50X ? if yes can someone be kind enough to explain me how to compile them in Aleos dev studio (they have dependencies, c files …) .
thanks in advance for your kind support.
regards
Olivier
Hi @olivier.beon
Yes, it is. PULLBACK has not been implemented.
elseif (message_type == MQTT.message.TYPE_PUBACK) then
print(“MQTT.client:parse_message(): PUBACK – UNIMPLEMENTED --”) – TODO
@rjacolin Can you please provide mqtt_library.lua with QOS level 1?
Please refer to README.md file in the source code. It contains instructions on how to install and run tests on these source codes.
Hi @Donald
Is there a way to implement this with Sparkplug B? I initially tried to compile C with Lua into a Shared Object (.so) file but Aleos seems to only import .lua files into the hardware. I currently use a LS300, but will also be using RV50 and RV50X later on.
Hi @josiah.regencia,
At the gateway’s perspective, it supports MQTT client communicating with the MQTT server. You can try the architecture topology if your MQTT server supports to collaborate with Sparkplug B.
