RV50X AirVantage Error code [/root/aleos/usr/readyagent/lua/ssl/https.lua:92: tlsv1 alert protocol version].]
Receiving above error within AirVanage whne trying to upload a file to an RV50X Gateway.
Below are the files in question, It appears I am using tlsv1_2 but the error code indicates that the deprecated tlsv1 is being used - what did I miss? Appreciate some insight, thank you!
Here is the body of https.lua:
– SOAP client over HTTPS.
– See Copyright notice in license.html
– $Id: https.lua,v 1.2 2009/05/27 13:22:41 tomas Exp $
local client = require"soap.client"
–client.https = require"ssl.https"
client.https = require"soap.client.myhttps"
Here is the body of myhttps.lua:
– LuaSec 0.7
– Copyright (C) 2009-2018 PUC-Rio
– Author: Pablo Musa
– Author: Tomas Guisasola
local socket = require(“socket”)
local ssl = require(“ssl”)
local ltn12 = require(“ltn12”)
local http = require(“socket.http”)
local url = require(“socket.url”)
local try = socket.try
– Module
local _M = {
_VERSION = “0.7”,
_COPYRIGHT = “LuaSec 0.7 - Copyright (C) 2009-2018 PUC-Rio”,
PORT = 443,
TIMEOUT = 60
– TLS configuration
local cfg = {
protocol = “tlsv1_2”,
options = {“all”, “no_sslv2”, “no_sslv3”, “no_tlsv1”},
verify = “none”,
– Auxiliar Functions
– Insert default HTTPS port.
local function default_https_port(u)
return url.build(url.parse(u, {port = _M.PORT}))
end
– Convert an URL to a table according to Luasocket needs.
local function urlstring_totable(url, body, result_table)
url = {
url = default_https_port(url),
method = body and “POST” or “GET”,
sink = ltn12.sink.table(result_table)
require ‘print’ p(“FMW>>>”, url)
if body then
url.source = ltn12.source.string(body)
url.headers = {
[“content-length”] = #body,
[“content-type”] = “application/x-www-form-urlencoded”,
end
return url
end
– Forward calls to the real connection object.
local function reg(conn)
local mt = getmetatable(conn.sock).__index
for name, method in pairs(mt) do
if type(method) == “function” then
conn[name] = function (self, …)
return method(self.sock, …)
end
end
end
end
– Return a function which performs the SSL/TLS connection.
local function tcp(params)
params = params or {}
– Default settings
for k, v in pairs(cfg) do
params[k] = params[k] or v
end
– Force client mode
params.mode = “client”
– ‘create’ function for LuaSocket
return function ()
local conn = {}
conn.sock = try(socket.tcp())
local st = getmetatable(conn.sock).__index.settimeout
function conn:settimeout(…)
return st(self.sock, _M.TIMEOUT)
end
– Replace TCP’s connection function
function conn:connect(host, port)
try(self.sock:connect(host, port))
self.sock = try(ssl.wrap(self.sock, params))
self.sock:sni(host)
self.sock:settimeout(_M.TIMEOUT)
try(self.sock:dohandshake())
reg(self, getmetatable(self.sock))
return 1
end
return conn
end
end
– Main Function
– Make a HTTP request over secure connection. This function receives
– the same parameters of LuaSocket’s HTTP module (except ‘proxy’ and
– ‘redirect’) plus LuaSec parameters.
– @param url mandatory (string or table)
– @param body optional (string)
– @return (string if url == string or 1), code, headers, status
local function request(url, body)
print(“MYHTTPS CALLED!!! >>>>>>>>>>>>>>>>>>>>>>>>>>>>”)
local result_table = {}
local stringrequest = type(url) == “string”
if stringrequest then
url = urlstring_totable(url, body, result_table)
else
url.url = default_https_port(url.url)
end
if http.PROXY or url.proxy then
return nil, “proxy not supported”
elseif url.redirect then
return nil, “redirect not supported”
elseif url.create then
return nil, “create function not permitted”
end
– New ‘create’ function to establish a secure connection
url.create = tcp(url)
local res, code, headers, status = http.request(url)
if res and stringrequest then
return table.concat(result_table), code, headers, status
end
return res, code, headers, status
end
– Export module
_M.request = request
return _M
