I am trying to use the MP70’s USB port to get Location reports to a Windows 10 device. The only USB Driver that I can find for this is for Window 7 and Windows 8 and do not seem to be working.
Does anyone know if there is a more recent USB Driver for the MP70?
Hi @zbray,
I am using this driver from Sierra source page on Windows10 and can get the device working properly.
Please refer to the following link: https://source.sierrawireless.com/resources/airlink/software_downloads/airlink_usb_driver/#sthash.EWt5zFYA.dpbs
I tried both the One-Click and the WHCK downloads from the Sierra Source page but was not able to get either to work.
Do you know if there was a specific way the driver had to be installed? Run the One-Click in compatibility mode, Windows 7, Windows 8? Be connected to the MP70 before running the install?
Hi @zbray,
Is there any error after you install the driver from the source page? If yes, please tell me the content of that error.
After installing the driver, what does your Device Manager page show, please give me a screenshot.
Hi @zbray,
According to your screenshot, the device is using with USB serial port. You can use Tera Term or PuTTy to type AT commands.
For purposes of getting Location reports, refer to Table D-24: Location AT Commands on page 574 of the AirLink MP Series Software Configuration Guide at the following link: https://source.sierrawireless.com/resources/airlink/software_reference_docs/airlink-mp-series---configuration-guide/#sthash.M58puwU6.dpbs
In addition, it’s simpler, you can use Location Reports using ACEmanager Web UI. Please refer to the Location Reports section on page 341 according to the attached document above.
