The way our vehicles work is that they record dashcam videos and then the videos upload over an MP70 Pro that is connected to the video server through an IPSEC VPN tunnel via LTE. Obviously the MP70 can connect to a wifi network as a client, and I can successfully configure the unit to connect to the wifi SSID that I want it to connect to. In other words, connection isn’t necessarily the problem.
Here is the problem: When a vehicle pulls up using the above stated setup, it loses all WAN connectivity. It successfully pulls down a WAN IP from the wifi network as it should, but I cannot ping or connect to anything on that network from the unit. I’ve played around with the Reliable Static Routing settings as it seems like that is what needs to be set to make this work, but no matter what I set, it does not work properly. I don’t know if this is an issue because of the existing VPN tunnel that is running or what. I have also messed around with WAN priority with no luck. Any ideas on how I’m not setting the configuration correctly?
