miniRide (EMD1100Z) does not find satellites.
297.661 Trace IP 3 OPEN AT NMEA send info. Length is 39
297.724 Trace IP 3 OPEN AT NMEA send info. Length is 40
297.789 Trace IP 2 Got ER_PVT_AVAIL
297.801 Trace IP 3 OPEN AT NMEA send info. Length is 50
297.865 Trace IP 20 [ADL] tmr subs ; id 5 ; hdlr 10002750 ; val 3 ; cycl 0
297.911 Trace IP 3 DATAGPS Data Handler: 14 14
298.082 Trace IP 3 DATAGPS Data Handler: 124 138
298.254 Trace IP 3 DATAGPS Data Handler: 124 262
298.520 Trace IP 3 DATAGPS Data Handler: 90 352
298.770 Trace IP 3 DATAGPS Data Handler: 124 476
299.020 Trace IP 3 DATAGPS Data Handler: 124 600
299.301 Trace IP 3 DATAGPS Control Event Handler : 7
299.319 Trace IP 2 ErideDataIn Check
299.332 Trace IP 2 ErideCore Enter 600
299.676 Trace IP 25 FCM Snd Data 0 11 : 0
299.693 Trace IP 3 AppPutGpsData Tx Ret: 0
299.852 Trace IP 25 FCM Snd Data 0 8 : 0
299.865 Trace IP 3 AppPutGpsData Tx Ret: 0
300.067 Trace IP 25 FCM Snd Data 0 8 : 0
300.084 Trace IP 3 AppPutGpsData Tx Ret: 0
300.372 Trace IP 25 FCM Snd Data 0 20 : 0
300.379 Trace IP 3 AppPutGpsData Tx Ret: 0
300.536 Trace IP 25 FCM Snd Data 0 20 : 0
300.558 Trace IP 3 AppPutGpsData Tx Ret: 0
300.707 Trace IP 25 FCM Snd Data 0 20 : 0
300.723 Trace IP 3 AppPutGpsData Tx Ret: 0
300.741 Trace IP 3 AppWriteDiagSerial
300.754 Trace IP 3 AppWriteDiagSerial
300.770 Trace IP 3 AppWriteDiagSerial
300.832 Trace IP 2 ErideCore:
300.852 Trace IP 2 ErideCore Exit 30
300.864 Trace IP 20 [ADL] tmr subs ; id 6 ; hdlr 10002750 ; val 3 ; cycl 0
300.911 Trace IP 3 DATAGPS Data Handler: 45 45
301.082 Trace IP 3 DATAGPS Data Handler: 124 169
301.254 Trace IP 3 DATAGPS Data Handler: 124 293
301.520 Trace IP 3 DATAGPS Data Handler: 92 385
301.770 Trace IP 3 DATAGPS Data Handler: 124 509
302.020 Trace IP 3 DATAGPS Data Handler: 124 633
302.301 Trace IP 3 DATAGPS Control Event Handler : 7
302.317 Trace IP 2 ErideDataIn Check
302.332 Trace IP 2 ErideCore Enter 633
302.645 Trace IP 25 FCM Snd Data 0 11 : 0
302.661 Trace IP 3 AppPutGpsData Tx Ret: 0
302.818 Trace IP 25 FCM Snd Data 0 8 : 0
302.832 Trace IP 3 AppPutGpsData Tx Ret: 0
303.192 Trace IP 25 FCM Snd Data 0 20 : 0
303.207 Trace IP 3 AppPutGpsData Tx Ret: 0
303.224 Trace IP 3 AppWriteDiagSerial
303.238 Trace IP 3 AppWriteDiagSerial
303.286 Trace IP 2 ErideCore:
303.301 Trace IP 2 ErideCore Exit 2d
303.317 Trace IP 1 Location not valid
303.366 Trace IP 23 [ADL] Gpio Single Write 6 : 0
303.379 Trace IP 3 OPEN AT NMEA send info. Length is 68
303.442 Trace IP 3 OPEN AT NMEA send info. Length is 69
303.504 Trace IP 3 OPEN AT NMEA send info. Length is 46
303.569 Trace IP 3 OPEN AT NMEA send info. Length is 31
303.632 Trace IP 2 Hour is 0
303.645 Trace IP 2 Minutes is 1
303.661 Trace IP 2 Seconds are 8
303.677 Trace IP 2 Month is 8
303.697 Trace IP 2 Day is 22
303.708 Trace IP 2 Year is 1999
303.724 Trace IP 3 OPEN AT NMEA send info. Length is 39
303.786 Trace IP 3 OPEN AT NMEA send info. Length is 40
303.849 Trace IP 2 Got ER_PVT_AVAIL
303.864 Trace IP 3 OPEN AT NMEA send info. Length is 50
303.930 Trace IP 20 [ADL] tmr subs ; id 7 ; hdlr 10002750 ; val 3 ; cycl 0
Any ideas?
Can somebody show PCB for miniRide (contact@interdv.ru)?
