EM7565 - GNSS errors
Modem details:
Model: EM7565
Revision: SWI9X50C_01.09.04.00 6d3218 jenkins 2019/02/26 20:33:22
GPS NMEA details set:
AT!GPSNMEASENTENCE=C9FDF
Which means:
  • Enable all GP* sentences
  • Enable all GL* sentences
  • Enable all GN* sentences
  • Enable all GA* sentences
Errors seen:
  • Speed is always 0.0, no matter if there is movement or not. Applies to all RMC and VTG sentences.
  • Multiple GNGSA sentences are being produced. There are too many, and the final one contains an invalid field just before the CRC
  • Enabling GPDTM does not produce this sentence at all
  • Missing support for ZDA sentences (Time)
Here is output from the device:
$GLGSV,3,1,09,74,35,040,29,67,59,314,16,66,60,139,77,47,206,17F
$GLGSV,3,2,09,76,70,054,75,19,037,65,00,137,84,12,000,1
70
$GLGSV,3,3,09,83,07,306,148
$GPGSV,3,1,10,05,49,202,29,08,09,036,21,13,71,295,31,15,35,291,31,1
61
$GPGSV,3,2,10,21,12,312,21,28,46,125,35,30,52,066,44,07,19,061,163
$GPGSV,3,3,10,20,27,02,004,1
54
$GPGGA,171546.00,5114.148365,N,00312.975149,E,1,05,1.4,16.9,M,47.0,M,5A
$GAGGA,171546.00,5114.148365,N,00312.975149,E,1,00,1.4,16.9,M,47.0,M,4E
$GNGNS,171546.00,5114.148365,N,00312.975149,E,AAN,06,1.4,16.9,47.0,V
59
$GPVTG,253.4,T,255.6,M,0.0,N,0.0,K,A
27
$GAVTG,253.4,T,255.6,M,0.0,N,0.0,K,A36
$GPRMC,171546.00,A,5114.148365,N,00312.975149,E,0.0,253.4,301019,2.2,W,A,V
5C
$GARMC,171546.00,A,5114.148365,N,00312.975149,E,0.0,253.4,301019,2.2,W,A,V4D
$GPGSA,A,2,05,13,15,28,30,1.7,1.4,1.0,1
26
$GAGSA,A,1,23
$GNGSA,A,2,05,13,15,28,30,1.7,1.4,1.0,1
38
$GNGSA,A,2,74,1.7,1.4,1.0,232
$GNGSA,A,2,1.7,1.4,1.0
2F
$GNGSA,A,2,1.7,1.4,1.02F
$GNGSA,A,2,1.7,1.4,1.0,3
30
70
61
54
$GPGGA,171547.00,5114.148364,N,00312.975147,E,1,05,1.4,16.9,M,47.0,M,54
$GAGGA,171547.00,5114.148364,N,00312.975147,E,1,00,1.4,16.9,M,47.0,M,40
$GNGNS,171547.00,5114.148364,N,00312.975147,E,AAN,06,1.4,16.9,47.0,V
57
27
$GPRMC,171547.00,A,5114.148364,N,00312.975147,E,0.0,253.4,301019,2.2,W,A,V
52
$GARMC,171547.00,A,5114.148364,N,00312.975147,E,0.0,253.4,301019,2.2,W,A,V43
26
$GAGSA,A,1,23
38
2F
30
1st error: I cannot check your speed error because my condition doesn’t allow to test speed.
2nd & 3rd errors: I’ve not seen any errors as yours
4th error: The document doesn’t state that ZDA sentences are supported. Maybe this is a future improvement
$GPGGA,082330.00,0,42
$GAGGA,082330.00,0,53
$GNGNS,082330.00,NNN,39
$GPVTG,T,M,N,K,N
2C
$GAVTG,T,M,N,K,N
3D
$GPRMC,V,N
53
$GARMC,V,N42
$GPGSA,A,1,32
$GAGSA,A,1,23
$GNGSA,A,1,2C
$GAGSV,2,1,07,04,19,320,36,01,65,154,12,32,248,19,38,023,7
73
$GAGSV,2,2,07,21,42,053,31,21,201,33,24,191,7
4A
$GPGSV,3,1,11,10,59,002,12,20,060,14,21,305,20,71,087,1
65
$GPGSV,3,2,11,21,35,189,24,04,036,25,47,104,26,08,201,1
69
$GPGSV,3,3,11,29,02,144,31,45,244,32,30,333,15C
$GPGGA,082331.00,0,43
$GAGGA,082331.00,0,52
$GNGNS,082331.00,NNN,38
$GPVTG,T,M,N,K,N
2C
$GAVTG,T,M,N,K,N
3D
$GPRMC,V,N
53
$GARMC,V,N
42
$GPGSA,A,1,32
$GAGSA,A,1,23
$GNGSA,A,1,2C
73
4A
65
$GPGSV,3,2,11,21,35,189,24,04,036,25,47,104,26,08,201,169
5C
$GPGGA,082332.00,0,40
$GAGGA,082332.00,0,51
$GNGNS,082332.00,NNN,3B
$GPVTG,T,M,N,K,N
2C
$GAVTG,T,M,N,K,N
3D
$GPRMC,V,N
53
$GARMC,V,N42
$GPGSA,A,1,32
$GAGSA,A,1,23
$GNGSA,A,1,2C
$GAGSV,2,1,07,04,19,320,35,01,65,154,12,32,248,19,38,023,7
70
4A
$GPGSV,3,1,11,10,59,002,38,14,21,305,35,20,71,087,26,32,30,333,37,1
6E
$GPGSV,3,2,11,12,20,060,21,35,189,24,04,036,25,47,104,1
61
$GPGSV,3,3,11,26,08,201,29,02,144,31,45,244,152
$GPGGA,082332.44,0,40
$GAGGA,082332.44,0,51
$GNGNS,082332.44,NNN,3B
$GAGNS,082332.44,NNN,34
$GPVTG,T,M,N,K,N
2C
$GAVTG,T,M,N,K,N
3D
$GPRMC,V,N
53
$GARMC,V,N
42
$GPGSA,A,1,32
$GAGSA,A,1,23
$GNGSA,A,1,2C
$GPGGA,082333.00,0,41
$GAGGA,082333.00,0,50
$GNGNS,082333.00,NNN,3A
$GAGNS,082333.00,NNN,35
$GPVTG,T,M,N,K,N
2C
$GAVTG,T,M,N,K,N
3D
$GPRMC,V,N
53
$GARMC,V,N
42
$GPGSA,A,1,32
$GAGSA,A,1,23
$GNGSA,A,1,2C
$GPGSV,3,1,11,10,59,002,38,12,20,059,21,14,21,305,35,20,71,087,26,1
65
$GPGSV,3,2,11,24,04,036,28,25,47,104,24,32,30,333,36,21,35,189,1
6E
52
73
4A
$GPGGA,082334.00,1051.395595,N,10637.873009,E,1,05,2.0,24.5,M,-1.0,M,4F
$GPDTM,P90,0000.000009,S,00000.000002,W,0.998,W84
51
$GAGGA,082334.00,1051.395595,N,10637.873009,E,1,01,2.0,24.5,M,-1.0,M,5A
$GNGNS,082334.00,1051.395595,N,10637.873009,E,ANA,06,2.0,24.5,-1.0,V
4C
$GAGNS,082334.00,1051.395595,N,10637.873009,E,NNA,01,2.0,24.5,-1.0,V
4B
$GPVTG,0.0,T,0.9,M,0.0,N,0.0,K,A
2A
$GAVTG,0.0,T,0.9,M,0.0,N,0.0,K,A3B
$GPRMC,082334.00,A,1051.395595,N,10637.873009,E,0.0,0.0,041119,0.9,W,A,V
53
$GARMC,082334.00,A,1051.395595,N,10637.873009,E,0.0,0.0,041119,0.9,W,A,V42
$GPGSA,A,2,10,12,20,24,32,2.2,2.0,0.9,1
22
$GAGSA,A,2,04,2.2,2.0,0.9,332
$GNGSA,A,2,10,12,20,24,32,2.2,2.0,0.9,1
3C
$GNGSA,A,2,2.2,2.0,0.9,238
26
$GNGSA,A,2,193,194,2.2,2.0,0.921
$GNGSA,A,2,04,2.2,2.0,0.9,3
3D
@Vianney
Thanks for sharing.
Could you please add your current NMEA config?
AT!GPSNMEASENTENCE?
Which version are you running?
Issue 1 is the most severe one (Speed is always 0.0)
The other 3 are low prio
After rebooting the module multiple times, I’m now seeing GPDTM
Thanks!
@koenvandeputte
I use the same setting as yours.
Here is my setting:
ati9
Model: EM7565
ESN: 12803145987, 80300103
IMEI: 357756090004611
IMEI SV: 9
FSN: UF810187020206
+GCAP: +CGSM
at!gpsnmeasentence?
!GPSNMEASENTENCE: 0xC9FDF
Some more details on the issue regarding speed:
When only GPS sentences are enabled, speed is fine.
When the sentences for other constellations are enable, speed is always 0.0
Smells like a bug …
Ping.
Any update on this from Sierra dev team?
It’s pretty easy to simulate:
1
  • Only enable GPS sentence bits
  • Get a GPS fix
  • Move around (see speed in NMEA strings) --> OK
2
  • Enable GPS + GLONASS/GALILEO sentence bits
  • Get a GNSS fix
  • Move around (see speed in NMEA strings) --> BAD, speed is always 0.0
Retested on revision: SWI9X50C_01.11.00.00 5ba42f jenkins 2019/06/28 09:51:52
The main issue is still the same:
  • Speed is 0.0 in all sentences when other GNSS constellations besides GPS are also enabled
