Sierra Wireless EM7590 – GNSS Enabled but No Fix / No Satellite Info
Hi everyone,
I’m having trouble getting GNSS working on a Sierra Wireless EM7590 module.
The modem itself is working fine, but GPS/GNSS never gets a fix, and I always see “Not Available” or “FAILCODE = 4” when checking location status.
Here’s the situation and configuration so far:
AT
ATI3
Manufacturer: Sierra Wireless
Model: EM7590
Revision: SWIX12C_02.02.03.00 2024/01/29 23:36:42
SVN: 05
IMEI: 357999720511841
FSN: DX5341003705H1
TS.25: 2024.1.1
+GCAP: +CGSM
AT!GNSSCONFIG?
GPS:   1
GLONASS: 1
BDS:   1
GAL:   1
QZSS:  1
AT!GPSAUTOSTART?
 function: 1
 fixtype: 1
 maxtime: 255 seconds
 nmaxdist: 100 meters
 fixrate: 1 seconds
AT!GPSCONF?
0,1,"",4
AT!GPSLOC?
Not Available
AT!GPSNMEACONFIG?
Enabled: 1
Output Rate: 1
AT!GPSNMEASENTENCE?
!GPSNMEASENTENCE: 5F
AT!GPSSATINFO?
NO SAT INFO
AT!GPSSTATUS?
1980 01 06 6 00:58:00 Last Fix Status = FAIL, FAILCODE = 4
1980 01 06 6 00:58:01 Fix Session Status = ACTIVE
No TTFF available
AT!PCINFO?
State: Online
LPM voters - Temp:0, Volt:0, User:0, W_DISABLE:0, IMSWITCH:0, LWM2M:0
LPM persistence - None
AT!IMAGE?
TYPE SLOT STATUS LRU FAILURES UNIQUE_ID  BUILD_ID
FW  1  GOOD  1  0 0   ?_?     02.02.03.00_?
FW  2  EMPTY 0  0 0
FW  3  EMPTY 0  0 0
Max FW images: 3
Active FW image is at slot 1
PRI FF  GOOD  0  0 0   002.000_002 02.02.03.00_GENERIC
PRI FF  GOOD  0  0 0   002.001_002 02.02.03.00_ATT
PRI FF  GOOD  0  0 0   002.000_002 02.02.03.00_TMO
PRI FF  GOOD  0  0 0   002.001_003 02.02.03.00_VERIZON
Max PRI images: 25
AT!PRIID?
PRI Part Number: 000025C
Revision: 100.013_000
Customer: Generic
Carrier PRI: SWIX12C_02.02.03.00_GENERIC_002.000_002
AT!GPSSUPLURL?
supl.google.com
AT!GPSSUPLVER?
!GPSSUPLVER: 2
AT+WANT?
Preferred: 1
Current: 1
AT!CUSTOM?
!CUSTOM:
        "SIMLPA"       0x01
        "UIM2ENABLE"     0x01
        "GPSENABLE"     0x01
        "MBIMTYPE"      0x01
Any help or suggestions would be greatly appreciated.
Thanks!
Problem is it cannot view any satellite
Do you connect all antennas?
Did you test in outdoor area?
It is connected to antenna, and it is outdoor.
The antenna/setup is working with AMIT MDG100 and now I am trying to get it work with the EM7590 module
Is there any improvement for using latest firmware?
https://source.sierrawireless.com/resources/airprime/minicard/75xx/em7590/em7590-approved-fw-packages/
Other user can make the gnss work:
I have upgraded the firmware:
ATI3
Model: EM7590
Revision: SWIX12C_03.01.02.00 2025/04/25 14:37:44
SVN: 07
FSN: DX5341003705H1
TS.25: 2025.2.24
+GCAP: +CGSM
After few minutes it managed to pick up one satellite but with now location:
AT!GPSSATINFO?
Satellites in view: 1 (1980 01 06 6 00:08:24)
SV: 1 ELEV: 0.000 AZI: 0.000 SNR:25.000
AT!GPSLOC?
Not Available
AT!GPSSTATUS?
1980 01 06 6 00:05:31 Last Fix Status = FAIL, FAILCODE = 4
1980 01 06 6 00:05:31 Fix Session Status = ACTIVE
No TTFF available
This lasted for few minutes and then now it is back to no satellites:
AT!GPSSATINFO?
NO SAT INFO
how many satellite can AMIT MDG100 view?
Is that all three antennas have been connected to EM7590 module?
AMIT MDG100 is able to get a fixed location using 10 satellites:
AT+QGPSLOC=1
+QGPSLOC: 170332.0,5204.660492,N,00101.525047,W,0.6,167.0,2,335.10,0.0,0.0,081225,10
I am just connecting the GPS antenna for now.
how many EM7590 modules have you tested?
I am wondering if this is a particular module problem.
4 modules has been tested, could not get any working
so all modules can only view one satellite only?
could it be antenna problem?
No, no satellites at all. just manged to get one satellite at that one instance I mentioned earlier other than that no satellites at all.
Well the same antenna has been used with AMIT MDG100, and I did manage to get a location. So this proves the antenna is working, does not it?
i am not quite sure, as other user does not see this problem:
I have tested also with other antenna that again I know it is working since it has been used with AMIT MDG100 and managed to get a location indoor and outdoor. But still no luck!
Have you started the nmea frame with at!gpsfix command?
yes and it returns statements with no data
$GPRMC,,V,,,,,,,,,,N*53
$GPGSA,A,1,,,,,,,,,,,,,,,,*32
$GPGGA,,,,,,0,,,,,,,,*66
$GPVTG,,T,,M,,N,,K,N*2C
Probably you need to contact distributor for further investigation
what you are suspecting the problem is?
i am not quite sure…
since you can view one satellite, it seems not to be software issue
I would like to chime in here. I have several Panasonic Toughbooks FZ-55 MK3 with the EM7595 module. Recently, of the 12 I have deployed 5 clients have reported back that they no longer have a GPS location in their application. My test unit also suffered from this issue.
We install the drivers with the Location Sensor and NMEA COM port enabled. When this problem first started the NMEA port was missing from Device Manager, reinstalling the drivers would restore it. On my test unit I was able to restore functionality however on all the other FZ-55’s this has not been the case. I can restore the NMEA COM port port however no GPS data is able to come through and the Location Sensor also is not receiving GPS data.
This all happened after the last round of Microsoft Windows 11 patches. We deferred December and January patches because of many issues surrounding them. Once they rolled out it was only a matter of a few days before clients started reporting the issue.
Now I was able to restore GPS functionalty briefly on one end point by using a newer driver however it then stopped working.
There is only one difference between my end point that I was able to fix VS the others that I cannot. Trend Micro is not installed on it. Possibly there is a conflict between the patches and some Anti Virus products out there with the new MS patches. I removed Trend from another FZ-55, restarted and it did not fix the issue.
I did not try new firmware and I now recall the new driver is configured not to update firmware. I think I will look at that next.
I was able to update the firmware, the Location Sensor appears to be working. However the NMEA port is not allowing a connection. I wonder if I had two problems. I’ll look into the COM port problem, might be a Windows 11 setting somewhere or a new security feature.
