I tried to Download dwl file to the modem but I taked error …
error is >> *** MEMORY ALLOCATION ERROR ***
Is there anybody who can solve this problemm???
Thanks…
Thanks…
Well, we can give it a try… maybe some more questions can help you…
// Check that you are using the latest downloader...
if(Problem_with_Downloading_OpenAT_Application){
// Have you closed Open AT and erased the previous
// application and flash area (+wopen=0, +wopen=3, +wopen=4)?
// check the size of your application compared to the mem size
// of your module
else if(Problem_with_Downloading_GSM_core_Software){
// Check that you are using the right version of GSM core
// software to match the Open AT version.
else if(tried_everything_and_nothing_work){
// go and get a beer or two, and attack the stupid problem
// tomorrow again
// Snoooze
Ouestion:Have you closed Open AT and erased the previous
Yes İ did it.
Oestion:check the size of your application compared to the mem size
// of your module
Answer: I don’t think it’s about mem size because i Use same code 2 weeks ago…(when i try to download ;at the beginnig of the packed i take this error)
This problem occured after i download new program which compiled with Open At 3.02.
Ouestion:f(Problem_with_Downloading_GSM_core_Software){
Answer:I don’t think so as i sid i did it 1 weeks ago…
Ouestion:(tried_everything_and_nothing_work){
// tomorrow again
Answer: i will try your advice but i tried it too.
İs there anything that i couldn’t see…
Have you upgraded the module to OAT 3 then go back to OAT 2.xx ??
In this case the flash may be affected. You may ask Wavecom to get a special dwl file to be downloaded, to “clear” flash.
Hello again,
It could help with a detailed description of what SW you are using (both core and Open AT) and what you have done and what HW you are using, in short: all details…?
Can you download a precompiled Open AT sample?
When I’ve had problems with the download (Memory_Allocation_Error and also other errors and failed downloads) I have alwayes started from scratch and erased and disabled everything, then downloaded an updated downloader, then a known working core SW version with matching e2p files and config files, then a known working Open AT version.
And after every step, I’ve verified that the module got “normal” funcationality.
And most of the times I’ve ended up with a working unit
Please give us more info and you’ll see that we will solve this.
/Snoooze
thanks for your help
I solve the problem. it’s related downgrade…
Usually memory allocation error occur when the modem was downgraded…
