I am trying to test the RX diversity path as the primary path. I saw that we can use AT!RXDEN=0/1/2 . But when i use this command, it just gives error. When query with the comman, i.e. AT!RXDEN? i can see that the 01 diversity path is being selected. I can also see all these options when i use query command as
[i]"AT!RXDEN=?
!RXDEN: <WCDMA/LTE/TDSCDMA flag>
0 - Disable Rx diversity
1 - Enable Rx diversity
2 - Rx diversity as primary path (Not applicable for TDSCDMA, both paths are enabled)
AT!RXDEN=2
ERROR"[/i]
Is there something I am missing?
Besides using the AT command !RXDEN=, is there any setting in MC7455/EM7455 modem that will change diversity? We have several servers using this modem and we are seeing all three outputs (0, 1, 2) across these servers. To my knowledge we do not have any logic on our servers that is changing this setting.
Thank you!
Evan
