MC7455 drops internet for 9 seconds every few seconds
Hello, I’ve been having an issue where the MC7455 in my system, when paired with a GlobalSIM SIM card, repeatedly drops its connection to the internet for a period of about 9 seconds after working for a little over a second.
I noticed a similar issue in another post on here and I’ve included the responses my modem gives to the same commands that were requested in that topic.
AT!ENTERCND=“A710”
response:" "
ATI3
response: ‘Manufacturer: Sierra Wireless, Incorporated
Model: MC7455
Revision: SWI9X30C_02.24.05.06 r7040 CARMD-EV-FRMWR2 2017/05/19 06:23:09
MEID:
IMEI:
IMEI SV: 12
FSN:
+GCAP: +CGSM,+DS,+ES’
AT+CPIN?
response: ‘+CPIN: READY’
AT!BAND?
response: ‘Index, Name, GW Band Mask L Band Mask TDS Band Mask
00, All bands, 0002000007C00000 00000100330818DF 0000000000000000’
AT+CGDCONT?
response: ‘+CGDCONT: 1,“IPV4V6”,“vzwinternet”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 2,“IP”,“vzwinternet”,“0.0.0.0”,0,0,0,0
+CGDCONT: 3,“IP”,“mobiledata”,“0.0.0.0”,0,0,0,0
+CGDCONT: 4,“IPV4V6”,“mobiledata”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0’
AT!SELRAT?
response: ‘!SELRAT: 00, Automatic’
AT+COPS?
response: ‘+COPS: 0,0,“T-Mobile”,2’
AT+COPS=?
response: ‘+COPS: (1,“AT&T”,“AT&T”,“310410”,7),(1,“AT&T”,“AT&T”,“310410”,2),(1,“T-Mobile”,“T-Mobile”,“310260”,7),(2,“T-Mobile”,“T-Mobile”,“310260”,2),(1,“Verizon”,“Verizon”,“311480”,7),(1,“Sprint”,“Sprint”,“310120”,7),(1,“312 530”,“312 530”,“312530”,7),(1,“313 100”,“313 100”,“313100”,7),(1,“311 882”,“311 882”,“311882”,7),(1,“311 490”,“311 490”,“311490”,7),(0,1,2,3,4),(0,1,2)’
AT!IMPREF?
response: ‘!IMPREF:
preferred fw version: 02.24.05.06
preferred config name: GENERIC_002.026_000
current fw version: 02.24.05.06
current carrier name: GENERIC
current config name: GENERIC_002.026_000’
AT!IMAGE?
response: 'TYPE SLOT STATUS LRU FAILURES UNIQUE_ID BUILD_ID
FW 1 GOOD 2 0 0 ?? 02.24.05.06?
FW 2 GOOD 1 0 0 ?? 02.24.03.00?
FW 3 EMPTY 0 0 0
FW 4 EMPTY 0 0 0
Max FW images: 4
Active FW image is at slot 1
PRI FF GOOD 0 0 0 002.027_000 02.24.05.06_ATT
PRI FF GOOD 0 0 0 002.026_000 02.24.05.06_GENERIC
PRI FF GOOD 0 0 0 002.022_000 02.24.03.00_SPRINT
PRI FF GOOD 0 0 0 001.000_000 00.00.00.00_OEMPRI918
PRI FF GOOD 0 0 0 002.034_000 02.24.05.06_VERIZON
Max PRI images: 50’
AT!CUSTOM?
response: ‘!CUSTOM:
GPSENABLE 0x01
GPSLPM 0x01
IPV6ENABLE 0x01
UIM2ENABLE 0x01
SIMLPM 0x01
USBSERIALENABLE 0x01
SINGLEAPNSWITCH 0x01’
AT!PCINFO?
response: ‘State: Online
LPM voters - Temp:0, Volt:0, User:0, W_DISABLE:0, IMSWITCH:0, BIOS:0, LWM2M:0, OMADM:0, FOTA:0
LPM persistence - None’
AT!GETBAND?
response: '!GETBAND: WCDMA 1700 ’
Hi @nglugla
Please try it with “Fast.t-mobile.com” APN for T-Mobile operator.
Thanks for the suggestion Donald! However, with that change I can no longer connect at all. I am using a GlobalSIM SIM card, not a T-Mobile one.
Hi @nglugla
Please make sure the antenna is plugged into module and contact your SIM provider to check the correct APN.
Both of those steps had been taken. Ultimately I believe this issue was just a result of poor bandwidth on the network.
Please contact your network operator to check it.
