Connection issue with MC7455
Hi everyone,
I want to setup my MC7455 to use 4G on my computer. I’m with a Vodafone provider in Luxembourg and using the connection manager.
Right now the SIM card is definitely detected, but it’s endlessly searching for network… I really don’t know if I set it up wrong.
A few more info :
  • 4836 generic drivers
  • vodafone firmware (latest)
  • profile : all set to default values (no username, no password)
Any help is appreciated.
Cheers
what are the return of the followings?
ATi3
AT!entercnd=“A710”
at!impref?
at!band?
AT!selrat?
at+cpin?
at!gstatus?
at+cgdcont?
at+cfun?
at!uims?
BTW, does it work with the GENERIC PRI with latest FW?
Returns from? (Sorry i am a noob)
It doesn’t work with the latest generic firmware no.
I should specify that i installed the generic drivers 4836 (latest drivers don’t work).
they are AT commands, you can open modem port (see in device manager) by tera term and enter those AT commands
ATi3
Model: MC7455
Revision: SWI9X30C_02.24.03.00 r6978 CARMD-EV-FRMWR2 2017/03/02 13:36:45
MEID: 35457251218974
IMEI: 354572512189747
IMEI SV: 9
FSN: LQ238522430110
+GCAP: +CGSM
AT!entercnd=“A710”
ERROR
Command error…
at!impref?
!IMPREF:
preferred fw version: 02.24.03.00
preferred carrier name: VODAFONE
preferred config name: VODAFONE_001.001_002
current fw version: 02.24.03.00
current carrier name: VODAFONE
current config name: VODAFONE_001.001_002
at!band?
Index, Name
00, All bands
AT!selrat?
!SELRAT: 00, Automatic
at+cpin?
+CPIN: READY
at!gstatus?
!GSTATUS:
Current Time: 302 Temperature: 42
Reset Counter: 10 Mode: ONLINE
System mode: LTE PS state: Not attached
LTE band: B20 LTE bw: 10 MHz
LTE Rx chan: 6300 LTE Tx chan: 4294967295
LTE CA state: NOT ASSIGNED
EMM state: Deregistered Attach Needed
RRC state: RRC Idle
IMS reg state: No Srv
PCC RxM RSSI: -98 RSRP (dBm): -140
PCC RxD RSSI: -60 RSRP (dBm): -88
Tx Power: 0 TAC: 0001 (1)
RSRQ (dB): -11.0 Cell ID: 000FDD67 (1039719)
SINR (dB): 8.4
at+cgdcont?
+CGDCONT: 1,“IPV4V6”,“”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
at+cfun?
+CFUN: 1
at!uims?
!UIMS: 0
do you need to enter the APN for profile 1?
e.g
AT+CGDCONT=1,“IP”,“APN_test”
AT+CGDCONT=1,“IP”,“APN_test” returns an error.
I don’t know if it answers your question though
be careful of the double quote character "
You already get error on AT!ENTERCND=“A710”
AT!entercnd="A710"
ERROR
Command error…
With correct double quote :
AT!entercnd=“A710”
ERROR
Command error…
I don’t see problem:
ati3
Model: MC7455
MEID: 35907206012345
IMEI: 359072060123456
IMEI SV:  9
FSN: LQ650440012345
+GCAP: +CGSM
at!impref?
!IMPREF:
at+cgdcont?
+CGDCONT: 1,"IPV4V6","","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0
at+cgdcont=1,"IP","test"
at+Cgdcont?
+CGDCONT: 1,"IP","test","0.0.0.0",0,0,0,0
at!uims?
!UIMS: 0
at+cfun?
+CFUN: 1
Any clue why it isn’t connecting?
Am I setting the profile wrongly in Skylight manager?
you can try to close skylight and see if you can modify profile
You can also try in linux PC and see if you can modify the APN
I don’t know how I should define username, password, APN, etc.
did you check with network provider Vodafone?
No I didn’t check with the network provider.
Which information should I get from them?
I got the information from the provider, but they were all correct.
What’s weird is that I have two other computers with exact same configuration and it works on those two computers, the only thing that changed is the firmaware.
On the two working computer, the firmware was installed a few years ago :
9999999_9904930_SWI9X30C_02.24.03.00_00_VODAFONE_001.001_000
but I can’t install it now on this new computer that I am trying to set.
It says “Firmware download failed”
I am thinking if we can reproduce the exact same configuration, it should work.
Any clue how I can install this older version of the vodafone firmware?
do you mean you have three MC7455 on three PC?
On the two working computer, the firmware was:
On the NOK PC, the firmware of the MC7455 is SWI9X30C_02.24.03.00 with PRI
001.001_002.
