MC7455 Firmware Failing to Update
Hi everyone. I currently have a MC7455 that looks like it had some old firmware on it. I was having some speed and connectivity issues so I thought a firmware update would help. I have this modem plugged into a windows 8.1 desktop. After the firmware fails, I cannot connect to a cellular network, even after power cycling it. I just want to make it work again.
Diagnostics tab, it shows:
ATQ0V1E0 - OK
AT+GMM - MC7455
AT+FCLASS=? - 0,2.0
AT#CLS=? - COMMAND NOT SUPPORTED
AT+GCI? - COMMAND NOT SUPPORTED
AT+GCI=? - COMMAND NOT SUPPORTED
ATI1 - Manufacturer: Sierra Wireless, Incorporated
Model: MC7455
Revision: SWI9X30C_02.24.05.06 r7040 CARMD-EV-FRMWR2 2017/05/19 06:23:09
MEID: 35907206252730
IMEI: 359072062527300
IMEI SV: 12
FSN: LQ826545180110
+GCAP: +CGSM
ATI2 - Manufacturer: Sierra Wireless, Incorporated
Model: MC7455
IMEI SV: 12
FSN: LQ826545180110
+GCAP: +CGSM
ATI3 - Manufacturer: Sierra Wireless, Incorporated
Model: MC7455
IMEI SV: 12
FSN: LQ826545180110
+GCAP: +CGSM
ATI4 - Manufacturer: Sierra Wireless, Incorporated
Model: MC7455
IMEI SV: 12
FSN: LQ826545180110
+GCAP: +CGSM
ATI5 - Manufacturer: Sierra Wireless, Incorporated
Model: MC7455
IMEI SV: 12
FSN: LQ826545180110
+GCAP: +CGSM
ATI6 - Manufacturer: Sierra Wireless, Incorporated
Model: MC7455
IMEI SV: 12
FSN: LQ826545180110
+GCAP: +CGSM
ATI7 - Manufacturer: Sierra Wireless, Incorporated
Model: MC7455
IMEI SV: 12
FSN: LQ826545180110
+GCAP: +CGSM
I am using driver version 4581 and I also tried 4836.
Here are the results from at!image?
FW 1 GOOD 2 0 0 ?? 02.24.05.06?
FW 2 GOOD 1 0 0 ?? 02.24.03.00?
FW 3 EMPTY 0 0 0
FW 4 EMPTY 0 0 0
Max FW images: 4
Active FW image is at slot 255
PRI FF GOOD 0 0 0 002.027_000 02.24.05.06_ATT
PRI FF GOOD 0 0 0 002.026_000 02.24.05.06_GENERIC
PRI FF GOOD 0 0 0 002.022_000 02.24.03.00_SPRINT
PRI FF GOOD 0 0 0 001.000_000 00.00.00.00_OEMPRI918
PRI FF GOOD 0 0 0 002.034_000 02.24.05.06_VERIZON
Max PRI images: 50
I checked and the module you are using is an M2M/IoT SKU andI assume you are using the MC74xx USB 3.0 dev kit?
Also, please reference the EM/MC7455 AT command guide located on the Source: https://source.sierrawireless.com/devices/mc-series/mc7455/
Locate the latest 2.30.1.1 FW and see if you can upgrade to one of these builds.
Jon
