MC7455 and EM7455 LTE-CA (B1+B3)
Is it possible to enable the MC7455 and the EM7455 for LTE-CA (B1 + B3 / 2100+1800MHz)?
Or by a firmware update?
BR Rene
i also need LTE-CA with B1+B3.
how can we activate it?
thans
I also want to ask for carrier aggregation between band 1 and band 3.
Many providers will use band 1 for LTE instead 3G in the next years.
B1+B3 CA is not supported due to a hardware layout limitation in the design for the EM74xx/MC74xx. This cannot be fixed via a Firmware change.
Thanks & Regards,
Moderator
Does the EM7565 support B1+B3 CA?
How I can use CA B3+B7?
at!lteca?
Hardware:
LTEB1: B8,
LTEB2: B2, B5, B12, B29,
LTEB3: B7, B20,
LTEB4: B4, B5, B12, B13, B29,
LTEB5: B2, B4, B30,
LTEB7: B3, B7, B20,
LTEB8: B1,
LTEB12: B2, B4, B30,
LTEB13: B4,
LTEB20: B3, B7,
LTEB25:
LTEB26:
LTEB29:
LTEB30: B5, B12,
LTEB41: B41,
Permitted Bands:
LTEB1: B8,
LTEB2: B2, B5, B12,
LTEB3: B7, B20,
LTEB5: B2, B4,
LTEB7: B3, B7, B20,
LTEB8: B1,
LTEB12: B2, B4,
LTEB13: B4,
LTEB20: B3, B7,
LTEB25:
LTEB26:
LTEB41: B41,
Prune_ca_combos:
Empty
if
at!lteca=1
atc response is ok, but at!status CA still NOT ASSIGNED
AT!GSTATUS?
!GSTATUS:
Current Time:  17610		Temperature: 51
Reset Counter: 1		Mode:        ONLINE
System mode:   LTE        	PS state:    Attached
LTE band:      B3     		LTE bw:      15 MHz
LTE Rx chan:   1475		LTE Tx chan: 19475
LTE CA state:  NOT ASSIGNED
EMM state:     Registered     	Normal Service
RRC state:     RRC Connected
IMS reg state: No Srv
PCC RxM RSSI:  -53		RSRP (dBm):  -91
PCC RxD RSSI:  -64		RSRP (dBm):  -98
Tx Power:      -1		TAC:         0426 (1062)
RSRQ (dB):     -15.2		Cell ID:     0C63E601 (207873537)
SINR (dB):      0.2
