I am try learn about the configuration of eUICC on the MC7411. I wanted to know how to Program the SIM profile on the MC7411 modem? is it done via the AT commands or does it need any other software tool to do it ?
the operating system used is windows. any help would be appreciated.
thanks for the reply. I cannot see “manage sim profile” in the in the cellular setting. My windows is 22h2.
not sure if your module has connected the esim
you can also check the setting:
AT!CUSTOM?
!CUSTOM:
GPSENABLE 0x01
GPIOSARENABLE 0x01
GPSSEL 0x01
IPV6ENABLE 0x01
SIMHOTSWAPDIS 0x02
UIM2ENABLE 0x01
SIMLPM 0x02
USBSERIALENABLE 0x01
SINGLEAPNSWITCH 0x01
QXDMLOGENABLE 0x01
Thank you Jyi. i have check on two of the modules i have:
- EM7411 when compared with what you have attached earlier, the following are absent:
a. GPIOSARENABLED
b. GPSSEL
c. SIMHOTSWAPDIS
and in the MC7411 only the following are available :
a. GPSENABLE
b.IPV6EBNABLE
c. SIMLPM
d. SINGLEAPNSWITCH
c. QXDMLOGENABLE
For eUICC to work which setting have to be present?
I am not sure if your eUICC hardware is ready on your hardware
what is the return of “AT!CUSTOM=?”
i ran the command AT!CUTOM=? on the MC7411 and it returned the following:
AT!CUSTOM=?
!CUSTOM:
“GPSENABLE”
“GPSLPM”
“GPIOSARENABLE”
“GPSSEL”
“GPSREFLOC”
“IMSWITCHHIDE”
“IMCONFIG”
“IPV6ENABLE”
“WAKEHOSTEN”
“SIMHOTSWAPDIS”
“CFUNPERSISTEN”
“QMIDETACHEN”
“UIM2ENABLE”
“NETWORKNAMEFMT”
“SIMLPM”
“USBSERIALENABLE”
“PCSCDISABLE”
“DHCPRELAYENABLE”
“FLOWNOTIDISABLE”
“FASTENUMEN”
“CSVOICEREJECT”
“IPCHANNELRATEEN”
“SINGLEAPNSWITCH”
“DGENABLE”
“TXONINDICATION”
“ICMPINTSRVDIS”
“SUBNETMSKENABLE”
“QXDMLOGENABLE”
and on the EM7411 returned the following:
AT!CUSTOM=?
!CUSTOM:
“GPSENABLE”
“GPSLPM”
“GPIOSARENABLE”
“GPSSEL”
“GPSREFLOC”
“IMSWITCHHIDE”
“IMCONFIG”
“IPV6ENABLE”
“WAKEHOSTEN”
“SIMHOTSWAPDIS”
“CFUNPERSISTEN”
“QMIDETACHEN”
“UIM2ENABLE”
“NETWORKNAMEFMT”
“SIMLPM”
“USBSERIALENABLE”
“PCSCDISABLE”
“DHCPRELAYENABLE”
“FLOWNOTIDISABLE”
“FASTENUMEN”
“CSVOICEREJECT”
“IPCHANNELRATEEN”
“SINGLEAPNSWITCH”
“DGENABLE”
“TXONINDICATION”
“ICMPINTSRVDIS”
“SUBNETMSKENABLE”
“QXDMLOGENABLE”
then maybe you can set the same setting
I am not still sure if your eUICC hardware is ready on your hardware
