Hi all,
I’m wanting to manually set my device to use to a specific GSM band (in this case: mono-band mode 900 extended MHz) and I need to make sure that I’ve got this correct.
From reading the AT Commands Interface Guide for Firmware 7.44
I see that I can use +WFM to see currently enabled/disabled features.
AT+WFM=2
+WFM: "MONO900",0,0
+WFM: "MONO1800",0,0
+WFM: "MONO1900",0,0
+WFM: "BI9001800",0,0
+WFM: "BI9001900",0,0
+WFM: "MONO850",0,0
+WFM: "BI8501900",0,0
+WFM: "QUADBAND",1,0
+WFM: "EFR",1,0
+WFM: "HR",1,0
+WFM: "DTXDATA",1,0
+WFM: "DATA144",1,0
+WFM: "SIM3VONLY",0,0
+WFM: "SIM1V8ONLY",0,0
+WFM: "SIM1V8AND3V",1,0
+WFM: "SIMREMOVE",1,0
+WFM: "OFFWHENUNPLUG",0,0
+WFM: "SWITCHATT",1,0
+WFM: "CPHS",1,0
+WFM: "SIMSPEEDENH",1,0
+WFM: "LOCA",0,0
+WFM: "AMR",1,0
+WFM: "NT_6K",1,0
From this I can see that QUADBAND is currently enabled and I take it from the docs that only one band can be enabled at one time.
The Docs also mention that I need to use +WMBS for band selection.
The blurb for +WMBS says: This command is allowed only if the selected bands are supported (please refer to +WFM command).
Which from my understanding MONO900 is available just disabled?
So I check the current settings:
AT+WMBS?
+WMBS: 5,0
aka Dual-band mode 900E / 1800 MHz
Check the available settings:
AT+WMBS=?
+WMBS: (0,1,2,3,4,5,6,7),(0-1)
Showing that mode 1 (mono-band 900E MHz) is available
And to change it:
AT+WMBS=1,0
AT+WMBS?
+WMBS: 1,1
AT+CFUN=1 // Needs to restart to take effect
AT+WMBS?
+WMBS: 1,1
So at this stage I think that I’ve set it up, but checking +WFM
AT+WFM=2
+WFM: "MONO900",0,0 <------ Was expecting a 1,0 here
+WFM: "MONO850",0,0
+WFM: "QUADBAND",1,0 <------ Still enabled
+WFM: "EFR",1,0
+WFM: "HR",1,0
+WFM: "DTXDATA",1,0
+WFM: "DATA144",1,0
+WFM: "CPHS",1,0
+WFM: "LOCA",0,0
+WFM: "AMR",1,0
+WFM: "NT_6K",1,0
Have I actually set the device to use the specified band? Or is there something further that I need to do?
How can I test that it’s using the specified Band?
Any suggestions or help would be most appreciated.
