I booted up an LX40 router for the first time.
It booted up no problem.
I then changed the IP address in the ethernet settings and rebooted via the ACEmanager.
Since I hit reboot the router is stuck in standby mode.
Hi @oisin.gribben,
Welcome to our community!
- What is the voltage rating of the power source you are using for the LX40?
→ In the hardware user guide, it mentions that: The LX40 supports an operating voltage of 7 V–36 V, but because low voltage standby mode is enabled by default, you must supply more than 9 V at startup.
→ Please refer to page 20 of the LX40 Hardware User Guide at the following link: https://source.sierrawireless.com/resources/airlink/hardware_reference_docs/airlink_lx40_userguide/#sthash.1jQSQgTr.dpbs
- How does the LED behavior on the LX40 appear? Does the Power LED display solid red?
- Please refer to section ‘Low Voltage Standby Mode - How do I get my LX40 out of Low Voltage Standby mode?’ on page 513 of the Software Configuration User Guide for AirLink LX40 to see if it helps.
→ Link Software guide: https://source.sierrawireless.com/resources/airlink/software_reference_docs/airlink-lx40---configuration-guide/#sthash.jBHpAlZH.dpbs
