Hello people, I recently got into OpenAT.
I am trying to fool around with the XM0110. I understand that there is an AT command interface so I downloaded an empty project with the “Location” plugin included into the Q26 CPU.
I thought this would allow me to send AT commands like “AT+GPSINIT=1” over the serial interface, to my openAT application in order to start up the GPS functionality. The CPU responds with “ERROR” on any GPS command.
You need to include the location plug-in, and then select the GPS_AT_cmd sample in the Sample Selection section when creating the new project. This will give you all the AT commands, they are not included in the plug-in its self.
Don’t forget to start the application (AT+WOPEN=1) after downloading it to the module.
I am trying to rework an OpenAT application for it to work with the XM0110 GPS instead of a third party GPS module. I hope I can easily get it to send NMEA messsages so that I have to change the least possible because this code is a horror ;_;
The code that my company got me working on could as well have been written by the author of this article: thc.org/root/phun/unmaintain.html
If you are using the AT command sample code, getting NMEA strings is as easy as initialising the GPS (AT+GPSINIT=1), Configure the NMEA string (AT+GPSNMEA=1,1,FFFF) and start the GPS (AT+GPSSTART). Assuing you have everything wired up correctly, you should start receiving stanard NMEA strings (Described in the Location Plug-in AT command docs.
