Linux SDK Download
Hello guys,
How to donwload Linux SDK?
Please help me !
Thanks.
Marco
Hi Marco,
Are you sure you are looking for a Linux SDK for AirLink gateways ?
Shouldn’t your question rather be in the AirPrime module section of the forum ?
If not, then you should probably post your use case (maybe in private) so that we can help you find the best fitted solution for your needs.
Cheers
Hi Gillo,
thanks for your answer.
I have a AirLink GL61x0 programmable modem.
I need interface it with Linux to send AT commands
and use it for the internet (ppp) comunication.
I don’t know if it’s the correctly forum section.
Thanks.
Marco
Hi Marco,
I’m sorry to say that there is no such Linux SDK for AirLink GL61x0 . The available Linux SDK are for 3G modules (GL61 being based on a GPRS module).
But I understand you should be able to send AT commands and ppp connectivity pretty easily with Linux.
Indeed, there is a good chance that you get much support in the AirPrime section of the forum, since AirLink GL61 is based on an AirPrime module.
Please let me know if/when you post to the AirPrime forum, so that I can follow the topic.
Cheers
Gillo
