Hello!
I have a question about how Legato apps work. that apps can have third party libraries (for example PahoMQTT)? We tried to add that library several times but the program crashes.
Regards,
Pablo
Hello!
Regards,
Pablo
Pablo,
You might be better off posting this to the Legato forum at the below link as there are far more legato developers there who will be able to give you expert advice.
First question I would ask though is how did you try to ‘add’ it?
Hello Matt,
Thanks a lot. I will open a post on Legato forum as you suggest. I tried to add the library adding some parts to the code:
MQTT_pruebaComponent.c
#include “MQTTClient.h”
Component.cdef
sources:
//The component that has the c program
cflags:
//this folder has MQTTAsync.h, MQTTClient.h and MQTTClientPersistence.h
-I $CURDIR/…/Librerias
Console logs:
08:59:11 **** Incremental Build of configuration Target_Legato_Debug for project MQTT_prueba ****
make: Entering directory ‘C:\Legato\workspace\MQTT_prueba/Target_Legato_Debug’
cd …;mkapp -t wp750x -o /tmp/build/MQTT_prueba/Target_Legato_Debug -w /tmp/build/MQTT_prueba/Target_Legato_Debug -i “/legato/interfaces” -i “/legato/interfaces/wifi” -i “/legato/interfaces/atServices” -i “/legato/interfaces/supervisor” -i “/legato/interfaces/logDaemon” -i “/legato/interfaces/airVantage” -i “/legato/interfaces/secureStorage” -i “/legato/interfaces/positioning” -i “/legato/interfaces/modemServices” -i “C:\Users\USUARIO\Desktop\librerias” -s “/legato/components/fwupdate/platformAdaptor/default” -s “.” -s “/legato/modules/WiFi/service” -s “/legato/components/airVantage/platformAdaptor/default” -s “/legato/components/airVantage” -s “/legato/components/fwupdate” -s “/legato/modules/WiFi/apps/tools/wifi” -s “/legato/components/positioning/platformAdaptor/default” -s “/legato/components/positioning” -s “/legato/components/devMode” -s “/legato/components/secStore/platformAdaptor/default” -s “/legato/components/secStore” -s “/legato/components/uartMode/platformAdaptor/default” -s “/legato/components/modemServices/platformAdaptor/default” -s “/legato/components/atServices” -s “/legato/components/modemServices” -s “/legato/components” -s “/legato/components/uartMode” -s “/legato/components/audio/platformAdaptor/default” -s “/legato/apps/tools” -C -g -X -g -L -g MQTT_prueba.adef
[1/7] Compiling C source
[2/7] Compiling C source
[3/7] Linking C library
[4/7] Creating hard link
[5/7] Linking C executable
make: *** [target] Error 1
FAILED: /opt/swi/y17-ext/sysroots/x86_64-pokysdk-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-gcc --sysroot=/opt/swi/y17-ext/sysroots/armv7a-vfp-neon-poky-linux-gnueabi -o /tmp/build/MQTT_prueba/Target_Legato_Debug/app/MQTT_prueba/staging/read-only/bin/mqtt_prueba /tmp/build/MQTT_prueba/Target_Legato_Debug/app/MQTT_prueba/obj/mqtt_prueba/_main.c.o -rdynamic -Wl,–enable-new-dtags,-rpath="$ORIGIN/…/lib" -L/tmp/build/MQTT_prueba/Target_Legato_Debug/staging/read-only/lib “-L/tmp/build/MQTT_prueba/Target_Legato_Debug/staging/read-only/lib” -lComponent_MQTT_pruebaComponent “-L/tmp/build/MQTT_prueba/Target_Legato_Debug/staging/read-only/lib” -lComponent_MQTT_pruebaComponent “-L$LEGATO_BUILD/framework/lib” -llegato -lpthread -lrt -ldl -lm -g
/tmp/build/MQTT_prueba/Target_Legato_Debug/staging/read-only/lib/libComponent_MQTT_pruebaComponent.so: undefined reference to MQTTClient_disconnect' /tmp/build/MQTT_prueba/Target_Legato_Debug/staging/read-only/lib/libComponent_MQTT_pruebaComponent.so: undefined reference toMQTTClient_publishMessage’
/tmp/build/MQTT_prueba/Target_Legato_Debug/staging/read-only/lib/libComponent_MQTT_pruebaComponent.so: undefined reference to MQTTClient_connect' /tmp/build/MQTT_prueba/Target_Legato_Debug/staging/read-only/lib/libComponent_MQTT_pruebaComponent.so: undefined reference toMQTTClient_destroy’
/tmp/build/MQTT_prueba/Target_Legato_Debug/staging/read-only/lib/libComponent_MQTT_pruebaComponent.so: undefined reference to MQTTClient_waitForCompletion' /tmp/build/MQTT_prueba/Target_Legato_Debug/staging/read-only/lib/libComponent_MQTT_pruebaComponent.so: undefined reference toMQTTClient_create’
collect2: error: ld returned 1 exit status
ninja: build stopped: subcommand failed.
Makefile:44: recipe for target ‘target’ failed
make: Leaving directory ‘C:\Legato\workspace\MQTT_prueba/Target_Legato_Debug’
08:59:14 Build Finished (took 3s.518ms)
In some places i see that people uses .so files, but when I try to use them inside “ldflags” at Component.cdef, the error is “C:\Legato\workspace\MQTT_prueba/MQTT_pruebaComponent/…/Librerias/libpaho-mqtt3a.so: file not recognized: File format not recognized”.
Regards,
Pablo
