MQTT with FX30
I’am currently trying to publish some MQTT data with an FX30 CAT M modem but encounter some issue…
I’am using the SDK for FX30-CATM (Release 15.1.0.004 + Legato 21.05.0) and built a very small system:
#include "$LEGATO_ROOT/default.sdef"
apps:
    mqttClient
appSearch:
    $CURDIR/apps/mqttClient/
interfaceSearch:
The mqttClient API application is a copy from the SDK source : legato-af/apps/platformServices/mqttClient at master · legatoproject/legato-af · GitHub
But any other application using this API seems to not start (no message printed), I guess there is a problem with the API.
If I restart the API manually, i get this:
$ app start mqttClient
root@192.168.2.2's password:
There was an error.  Application 'mqttClient' could not be started.
Check the system log for error messages.
And the log:
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | app.c app_Start() 3589 | Starting app 'mqttClient'
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | app.c CreateFileLink() 2202 | Skipping file link '/dev/log' to '/legato/systems/current/appsWriteable/mqttClient/dev/log': Already exists
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | app.c CreateFileLink() 2202 | Skipping file link '/dev/null' to '/legato/systems/current/appsWriteable/mqttClient/dev/null': Already exists
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | app.c CreateFileLink() 2202 | Skipping file link '/dev/zero' to '/legato/systems/current/appsWriteable/mqttClient/dev/zero': Already exists
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | app.c CreateFileLink() 2202 | Skipping file link '/dev/urandom' to '/legato/systems/current/appsWriteable/mqttClient/dev/urandom': Already exists
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | app.c CreateFileLink() 2202 | Skipping file link '/legato/systems/current/lib/liblegato.so' to '/legato/systems/current/appsWriteable/mqttClient/lib/liblegato.so': Already exists
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | app.c CreateFileLink() 2202 | Skipping file link '/lib/ld-linux.so.3' to '/legato/systems/current/appsWriteable/mqttClient/lib/ld-linux.so.3': Already exists
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | app.c CreateFileLink() 2202 | Skipping file link '/lib/libc.so.6' to '/legato/systems/current/appsWriteable/mqttClient/lib/libc.so.6': Already exists
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | app.c CreateFileLink() 2202 | Skipping file link '/lib/libpthread.so.0' to '/legato/systems/current/appsWriteable/mqttClient/lib/libpthread.so.0': Already exists
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | app.c CreateFileLink() 2202 | Skipping file link '/lib/librt.so.1' to '/legato/systems/current/appsWriteable/mqttClient/lib/librt.so.1': Already exists
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | app.c CreateFileLink() 2202 | Skipping file link '/lib/libdl.so.2' to '/legato/systems/current/appsWriteable/mqttClient/lib/libdl.so.2': Already exists
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | app.c CreateFileLink() 2202 | Skipping file link '/lib/libgcc_s.so.1' to '/legato/systems/current/appsWriteable/mqttClient/lib/libgcc_s.so.1': Already exists
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | app.c CreateFileLink() 2202 | Skipping file link '/lib/libm.so.6' to '/legato/systems/current/appsWriteable/mqttClient/lib/libm.so.6': Already exists
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | app.c CreateFileLink() 2202 | Skipping file link '/usr/lib/libstdc++.so.6' to '/legato/systems/current/appsWriteable/mqttClient/lib/libstdc++.so.6': Already exists
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | app.c CreateFileLink() 2202 | Skipping file link '/lib/libresolv.so.2' to '/legato/systems/current/appsWriteable/mqttClient/lib/libresolv.so.2': Already exists
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | app.c CreateFileLink() 2202 | Skipping file link '/legato/systems/current/apps/mqttClient/read-only/lib/libpaho-mqtt3cs.so.1.0' to '/legato/systems/current/appsWriteable/mqttClient/l
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | app.c CreateFileLink() 2202 | Skipping file link '/legato/systems/current/apps/mqttClient/read-only/lib/libcrypto.so.1.1' to '/legato/systems/current/appsWriteable/mqttClient/lib/lib
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | app.c CreateFileLink() 2202 | Skipping file link '/legato/systems/current/apps/mqttClient/read-only/lib/libssl.so.1.1' to '/legato/systems/current/appsWriteable/mqttClient/lib/libssl
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | app.c CreateFileLink() 2202 | Skipping file link '/legato/systems/current/apps/mqttClient/read-only/lib/libComponent_mqttClientService.so' to '/legato/systems/current/appsWriteable/m
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | app.c CreateFileLink() 2202 | Skipping file link '/legato/systems/current/apps/mqttClient/read-only/lib/libpaho-mqtt3cs.so.1' to '/legato/systems/current/appsWriteable/mqttClient/lib
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | app.c CreateFileLink() 2202 | Skipping file link '/legato/systems/current/apps/mqttClient/read-only/lib/libpaho-mqtt3cs.so' to '/legato/systems/current/appsWriteable/mqttClient/lib/l
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | app.c CreateFileLink() 2202 | Skipping file link '/legato/systems/current/apps/mqttClient/read-only/bin/mqttClientService' to '/legato/systems/current/appsWriteable/mqttClient/bin/mq
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | app.c CreateDirLink() 2094 | Skipping directory link '/etc/ssl' to '/legato/systems/current/appsWriteable/mqttClient/etc/ssl': Already exists
Feb 25 09:14:14 fx30 user.err Legato: =ERR= | supervisor[9560]/supervisor T=main | app.c CreateFileLink() 2160 | Could not stat file at '/usr/lib/libcrypto.so.1.0.2'. No such file or directory
Feb 25 09:14:14 fx30 user.err Legato: =ERR= | supervisor[9560]/supervisor T=main | app.c CreateFileLink() 2277 | Failed to create link at '/usr/lib/libcrypto.so.1.0.2' in app 'mqttClient'.
Feb 25 09:14:14 fx30 user.err Legato: =ERR= | supervisor[9560]/supervisor T=main | app.c app_Start() 3621 | Failed to set Smack rules or set up app area.
Feb 25 09:14:14 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | supervisor.c SigChildHandler() 885 | Reaping unconfigured child process 9905.
Feb 25 09:14:28 fx30 user.info Legato:  INFO | supervisor[9560]/supervisor T=main | supervisor.c HandleRebootExpiry() 633 | Expired reboot timer
Any idea on how to fix theses errors ?
How about using this app?
On the Component.cdef file of this example application, there is dependency:
requires:{ api: { mqtt.api } }.
Binded to the mqttClient API in the mqttPublisher.adef file:
bindings: testPublisher.testPublisher.mqtt -> mqttClient.mqtt.
Since the mqttClient API application failed to start, this example application can’t start too.
I have tryed to add a debug print LE_INFO("== testPublisher START =="); in the first line of COMPONENT_INIT function, but this print never appears in the log.
I saw these lines in your log:
you might need to check \components\3rdParty\paho.mqtt.c\Component.c
As i saw these libraries are hardcoded with version, it might not be matched to your current module
Effectively, in Component file, we can found an hardcoded version :
        /usr/lib/ssl/openssl.cnf    /usr/lib/ssl/
        /usr/lib/libssl.so.1.0.2    /usr/lib/
        /usr/lib/libcrypto.so.1.0.2 /usr/lib/
The openssl.cnf file is also in the wrong folder, it should be in /etc instead of /lib.
I edited the file with this new lines:
        #if file_exists(${LEGATO_SYSROOT}/usr/lib/ssl/openssl.cnf)
        #endif
        #if file_exists(${LEGATO_SYSROOT}/etc/ssl/openssl.cnf)
            /etc/ssl/openssl.cnf         /etc/ssl/
        #endif
        #if file_exists(${LEGATO_SYSROOT}/usr/lib/libssl.so.1.1)
            /usr/lib/libssl.so.1.1       /usr/lib/
            /usr/lib/libcrypto.so.1.1    /usr/lib/
        #elif file_exists(${LEGATO_SYSROOT}/usr/lib/libssl.so.1.0.2)
        #elif file_exists(${LEGATO_SYSROOT}/usr/lib/libssl.so.1.0.0)
            /usr/lib/libssl.so.1.0.0     /usr/lib/
            /usr/lib/libcrypto.so.1.0.0  /usr/lib/
        #else
            /openssl/not/found /lib/
        #endif
The mqttClient API application is now started normally, GOOD!
But still impossible to connect…
After many tests, I noticied that curl and wget commands failed to connect on HTTP service (port 80), only HTTPS was working, maybe some firewall…
And here it is:
root@fx30:~# iptables -L
Chain INPUT (policy DROP)
target     prot opt source               destination
ACCEPT     udp  --  anywhere             anywhere             udp spt:ntp ctstate ESTABLISHED
ACCEPT     udp  --  anywhere             anywhere             udp spt:443 state ESTABLISHED
ACCEPT     tcp  --  anywhere             anywhere             tcp spt:https state ESTABLISHED
ACCEPT     udp  --  anywhere             anywhere             udp spt:5686 state ESTABLISHED
ACCEPT     udp  --  anywhere             anywhere             udp spt:5684 state ESTABLISHED
ACCEPT     icmp --  anywhere             anywhere             icmp echo-reply state ESTABLISHED
ACCEPT     tcp  --  anywhere             anywhere             tcp spt:domain state ESTABLISHED
ACCEPT     udp  --  anywhere             anywhere             udp spt:domain state ESTABLISHED
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:ssh
ACCEPT     icmp --  anywhere             anywhere             icmp echo-request
ACCEPT     udp  --  anywhere             anywhere             udp spts:bootps:bootpc dpts:bootps:bootpc
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
The INPUT policy set to DROP and some exeption on ESTABLISHED, including the https port.
This explains why i failed to connect on port 80 with curl/wget and also failed to connect on port 1883 or 8883 for MQTT.
Now, i have some questions:
  • Why use a such aggressive IPTABLE configuration in the default image ?
  • Is there a way to change this configuration in the generated system update file by mksys ?
see if this helps to configure the firewall:
