I am trying to build the Legato Systems tutorial (Legato Systems - Legato Docs) and getting all sorts of errors.
First, I got errors about not being able to find .api files, etc. I found a post that said the older legato doesn’t support the appSearch and to specify paths. So I did.
That got me to the next error.
mark@ubuntu:~/workspace/system-test$ mksys -t wp85 mySystem.sdef
[1/1] Regenerating build script
[78/479] Generating IPC interface code
FAILED: ifgen --output-dir ./_build_mySystem/wp85/api/ddc97fd9693eb6f64315e21eec71d1b3/client --gen-interface --import-dir /home/mark/FX30S/legato/interfaces --import-dir /home/mark/FX30S/legato/framework/c/inc --import-dir . --import-dir interfaces/modemServices --import-dir interfaces/positioning --import-dir ./interfaces /home/mark/FX30S/legato/interfaces/modemServices/le_sim.api
Parsing Error near line 313, column 10
Expected W:(abcd…,abcd…)
00310 : */
00311 :
00312 :
→ 00313 : USETYPES $LEGATO_ROOT/interfaces/modemServices/le_mdmDefs.api;
00314 :
00315 :
00316 :
/home/mark/FX30S/legato/interfaces/modemServices/le_sim.api:313:10: error: Expected W:(abcd…,abcd…)
FAILED: ifgen --output-dir ./_build_mySystem/wp85/api/ddc97fd9693eb6f64315e21eec71d1b3/client --gen-client --gen-local --name-prefix le_sim --file-prefix le_sim --import-dir /home/mark/FX30S/legato/interfaces --import-dir /home/mark/FX30S/legato/framework/c/inc --import-dir . --import-dir interfaces/modemServices --import-dir interfaces/positioning --import-dir ./interfaces /home/mark/FX30S/legato/interfaces/modemServices/le_sim.api
00310 : */
00311 :
00312 :
00314 :
00315 :
00316 :
FAILED: ifgen --output-dir ./_build_mySystem/wp85/api/9cc40e77ebe4270d33a41c26c8944350/client --gen-client --gen-interface --gen-local --name-prefix le_cellnet --file-prefix le_cellnet --import-dir /home/mark/FX30S/legato/interfaces --import-dir /home/mark/FX30S/legato/framework/c/inc --import-dir . --import-dir interfaces/modemServices --import-dir interfaces/positioning --import-dir ./interfaces /home/mark/FX30S/legato/interfaces/le_cellnet.api
Parsing Error near line 90, column 10
00087 : /
00088 :
00089 :
→ 00090 : USETYPES $LEGATO_ROOT/interfaces/modemServices/le_sim.api;
00091 :
00092 :
00093 : /*
/home/mark/FX30S/legato/interfaces/le_cellnet.api:90:10: error: Expected W:(abcd…,abcd…)
[78/479] Compiling C source
ninja: build stopped: subcommand failed.
Not sure where to go from here.
If I change the paths any, I get an error earlier in the process that it can’t find the file.
Obviously, something isn’t right. Any suggestions?
Are there tutorials for legato 16.10.1.m3 instead of trying to use newer tutorials?
mark
