KSRAT on modem RHL7692
Hi!
I have a problem with some sites that have good LTE and GSM connectivity. In these locations, some modems connect to the GSM network, even with a strong signal from the LTE network in the same region. So, to solve this problem I’m trying to change the radio access technology in a modem HL7692 with firmware RHL769x.2.26.180400.201802141030.x7120m_1 . The allowed modes are 1, 5, 8 and 9 and when I try to change to 8, for example, I’m getting a CME ERROR: 3.
Look at the snipned bellow:
Manufacturer of modem: Sierra Wireless
Type of modem: HL7692
Modem firmware version: RHL769x.2.26.180400.201802141030.x7120m_1
IMEI: 355465071111120
Serial number: VE851440900810
AT+KSRAT?
+KSRAT: 9
AT+KSRAT=9
+CME ERROR: 3
AT+KSRAT=?
+KSRAT: (1,5,8,9)
AT+KSRAT=8
+CME ERROR: 3
AT+KSRAT=5
+CME ERROR: 3
can someone help with this issue?
Hi @rafael.dias
Please upgrade the HL7692 to the latest firmware 2.27 and retry.
This issue has not been reproduced on firmware HL7692 2.27 on my side.
The log file is attached.HL7692.txt (391 Bytes)
You can get the firmware HL7692 here AirPrime HL7692 Firmware
Help to tick “Solutions” if your question is answered.
Hi @Donald,
many thanks for your message.
it is possible to update the modem using update over the air?
@rafael.dias
Hi, yes you can update the unit over the air using the FOTA server as it has the delta file to go from 2.26 to 2.27.
