Is the modem hl7802 fallback to 2g automatically?
I have configured the PRL as says the command interface guide using +KSELACQ:
// In mode 0, set RAT1 to 1 (CAT-M), RAT2 to 2 (NB-IoT), and RAT3 to 3 (GSM). After
manually rebooting, the module will begin scanning for CAT-M cells first. If no cells are
found, module will fallback first to NB-IoT, then GSM, then restart from the beginning of
the PRL.
AT+KSELACQ=0,1,2,3
The KSRAT is set to 0 as says the guide:
0 In the Write format, =0 is used to switch to the first RAT
in the preferred RAT list (PRL), and fall back to subsequent RATS
in the PRL if cell coverage is lost. If the PRL is empty, switch to
CAT-M1. To set the PRL, see AT+KSELACQ
However when I start a communication, it seems not scan other cells but modifying manually to 2G, my equipment transmits.
The FW version is 4.6.8.0
I hope someone can help me to understand better.
Thank you!
