Installed the ALEOS Dev Studio on a machine has Java installed.
When launching DeveloperStudioALEOS.exe, we received an error:
“A Java Runtime Environment (JRE) or Java Development Kit (JDK) must be available in order to run Eclipse. No Java virtual machine was found after searching the following locations:
C:\ALEOS\DEV Studio\jre\bin\javaw.exe
javaw.exe in your current PATH”
What is the best way to resolve this and get DeveloperStudioALEOS to run?
Okay - Never mind - I answered my own question.
But for anyone who wants to know…
If you get a Java error when launching Dev Studio for 1st time…
Go to your the folder where your “DeveloperStudioALEOS.exe” resides.
You will see a file called “DeveloperStudioALEOS.ini”.
Open the file in notepad.
It will likely have all the Eclipse arguments on one line.
-vmargs-XX:PermSize=512M-XX:MaxPermSize=512M-Xms40m-Xmx512m
You can add a before each dash to clean it up - so now it looks like this:
-vmargs
-XX:PermSize=512M
-Xms40m
-Xmx512m
Now add a path to your Java Virtual Machine DLL file (which is located somewhere in your Windows system).
Most likely the path to that file will be under “C:\Program File (x86)\Java\jre7\bin\client”.
Assuming that is the case…add the full path to that DLL at the beginning of the ini file.
So now your “DeveloperStudioALEOS.ini” looks like this:
-vm
C:\Program Files (x86)\Java\jre7\bin\client\jvm.dll
-vmargs
-XX:PermSize=512M
-Xms40m
-Xmx512m
Now simply save that ini file again, overwriting the previous version.
Launch DeveloperStudioALEOS.exe.
BOOM! It works.
Hope that was useful to someone.
There is also a more generic solution (I would actually consider it as the right one
), which is to actually add a JRE or JDK to your PATH, in the Windows Environment Variables (as suggested by the error message).
Everything is explained on the java web site: java.com/en/download/help/path.xml
Cheers
.G.
