Error Installing AAF Developer Studio
I downloaded the tar.gz file for AAF Developer Studio. Whenever I try to run the Developer Studio, I get this error always: !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.simpleconfigurator_1.0.300.v20110815-1744.jar was not resolved.
I have a Mac OS 11.1. I have Installed Java 8 and Java 11 on my laptop and my Eclipse supports JVM 11+ only.
Any ideas on how to fix? I can’t seem to use JVM 1.8 with the current Eclipse and there doesn’t seem to be Eclipse that can support 1.8 also. Hoping for a response. Thanks
Hi @josiah.regencia
I can successfully install AAF Developer Studio 2.0.0 version on Windows 10 64bits Java 1.8 version. I only installed Java 1.8 64bit version.
ALEOS AF Developer Studio (IDE)
java -version
java version “1.8.0_251”
Java™ SE Runtime Environment (build 1.8.0_251-b08)
Java HotSpot™ 64-Bit Server VM (build 25.251-b08, mixed mode)
You can try uninstalling Java 11 version. Please install only Java 1.8 version.
Help to tick “Solutions” if your question is answered.
Hi @Donald
Thank you for your response. I did try this one but it showed me an error that the virtual machine was not loaded. That error was fixed when I installed Java 11 with Eclipse instead. But I will try this part again. Thanks
Hi @Donald,
I uninstalled Java 11 and installed Java 1.8.
So I now have,
java version “1.8.0_271”
Java™ SE Runtime Environment (build 1.8.0_271-b09)
Java HotSpot™ 64-Bit Server VM (build 25.271-b09, mixed mode)
My JAVA_HOME: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home
However: I keep on getting this error message:
The DeveloperStudioALEOS executable launcher was unable to locate its
companion shared library.
Whenever I unpack it using: gunzip -c ALEOS_AF_Dev_Studio_v2.0.0-macosx.cocoa.x86_64.tar.gz | tar xopf -
I get this error message: Failed to create the Java Virtual Machine.
I don’t have Eclipse installed since latest Eclipse only supports Java VM 11 or later.
Have you experienced this before? Thanks.
Josiah
Hi josiah.regencia ,
Please try to run from the install directory.
***xattr -d com.apple.quarantine ****
https://vensim.com/faqs/mac-problem-after-upgrading-to-osx-catalina-app-is-damaged-and-cant-be-opened-you-should-move-it-to-the-trash/
http://www.engineering.union.edu/howto/damaged.html
https://developer.apple.com/forums/thread/119916
Hi Donald,
Thank you for this. This still shows the same error. My theory about this is that because my current version of Mac OS doesn’t support Eclipse 4.2. I have a vm running an Ubuntu 18.04 and the AAF works perfectly. Thanks
