I want to test debugging with RTE, and I created a new hello world project. I use the latest Framework, OS, Firmware. However, when I get to the step “Toolchains and Configutations” in the New Open AT Project wizard the option for [RTE] MinGW is not there at all. The only option I have is [Target] ARM EABI GCC. If I select the older Framework 2.35 then the option [RTE] MinGW appears in the “Toolchains and Configuraitons” step, but I cannot select it since it is grayed out.
I read several times in different forum threads that in the future RTE debugging won’t be supported (especially by user daav, which I believe is a Sierra employee). So, has that time come?
The weird thing is that I remember that I was able to select [RTE] MinGW when I first installed DS a month or so ago, but I can’t any more. In the meantime I might have updated DS to the latest version (I have 2.2.1.201206182209-R9667), and that might have got rid off the [RTE] MinGW option. If that is not the case, then is there some kind of change to the DS configuration to be able to do RTE debugging?
Thanks!
