I wanted to use LX40, but before buying it, i have a question.
The antenna are mark as optional, but is the LTE work if there is no antenna connect to the port.
I will use the ethernet so i don’t need one for the wifi.
thanks
thanks
According to the document, connecting an antenna to the SMA Diversity antenna connector for 4G networks is necessary.
For more details, refer to Section 3 - Connect the Antennas on page 18 in the attached document below:
https://source.sierrawireless.com/resources/airlink/hardware_reference_docs/airlink_lx40_userguide/
Thanks for your answer
