I am using the Q2687 G, I am doing some serious processing, I already set the clock mode to BOOST (max clock speed), I would like to know is there any way to get the CPU to process only my code and then afterwards do the normal OS operations, basically setting my code to higher priority?
I doubt that you can get any more out of the Q2687.
The Radio/GSM application section has priority (due to some very tight real-time constraints) and the OpenAT application is run as a task/function within the overall operating system - and you don’t have ANY control over the GSM/radio software.
Maybe you could shut down the GSM stack (AT+CFUN???) and then see if you have any more processing cycles - but I doubt it!
I can’t shutdown the gsm stack, we have developed a voice over IP application, works very well, it’s just the conversion time from PCM to AMR. The AMR codec has got optimization for the ARM4 and 5E processors, that uses assembler in the C code, but when I activate this I get a lot of bad command with the assembler code, I know this code work in other environments, so I assume it is open at, please let me know if there is any issues with inserting assembler into Open AT c?
Are you sure that the Wavecom CPU is an ARM4 or ARM5E? I seem to recall reading somewhere (but can’t put my finger on it at the moment) that the WMP100 is based on the ARM7 or ARM9 core. If that is the case, then you may well have issues with different ASM op-codes between processor variants. Spend some time going through the WMP100 docs and see what you can find…
As far as inlining assembler into C, remember that OpenAT is using (by default) the GCC cross-compiler. A howto on inlining assembly code for GCC is available here. There’s plenty of other notes available on the internet - search for gcc assembler in Google.
Ya, the voip is nice to have completed, I will set a complete post later on about the implementation.
I have read up about the ARM core, it is the ARM946, now this ARM has got build in DSP functions, that is why wavecom support the AMR voice codec, this is supported by the ARM processor, I do inline assembler coding to try and make use of the DSP functions, but get “bad command” errors, here is an example of one of the inline assembler code fragments that make use of the DSP functions:
This function gives me the following error: “bad instruction `smulbb r0,r6,r3’”
Is there anything I need to set before using inline assembler? Why is this code not working although it is supported by the ARM946 processor?
I saw that you need to include “dspfns.h” for the GCC compiler to access the DSP functions, but this is nowhere to be found in the OpenAT environment… Please help, where can I find the necessary include files to use the DSP functions in OpenAT
