Include ed lib in OPEN AT v400 b1
i worked with ed lib v3.10 for module M1306B
ed lib was included successfully
now i have the 2686 and open at 4
and i have linker error for all ed lib functions
/cygdrive/c/Wavecom/Tst/gcc/out/hello_world.c:89: undefined reference to `ed_SendDataExt’
project mak file listing:
Include this file only one time
ifndef MAKEFILE_INCLUDED
MAKEFILE_INCLUDED = YES
Library module (lib) or Binary module (bin)
PROCESS = bin
Set the used Api for Open-AT : ADL or OAT (standard Open-AT API)
API = ADL
Use the old task interface (ON/OFF)
USE_OLD_TASK_INTERFACE = {USE_OLD_TASK}
Set GCC Call Stack factor (to increase Call Stack size automatically for GCC compiler)
GCC_STACK_SIZE_FACTOR =
List of source files of the library or executable to generate
SRC_C_LIST =
nx19.c
hello_world.c
convert.c \
List of assembler files of the library or executable to generate
SRC_ASM_LIST = \
List of objects real names to use for making binary file
EXTERNAL_OBJ_LIST = \
List of objects prefixed names to use for making binary file
PREFIXED_OBJ_LIST = \
List of libraries real names to use for making binary file
EXTERNAL_LIB_LIST =
/cygdrive/C/OpenAT/Tools/GCC/4.0.1.0/arm-elf/lib/thumb/interwork/libm.a \
List of libraries prefixed names to use for making binary file
PREFIXED_LIB_LIST = \
Add-on used library list (as TCP/IP library, for example)
OTHER_LIB_LIST =
TCPIP \
Compilation flags
PP_OPT_COMMON =
OAT_API_VERSION=400 \
Path for code C files
PATH_C =
…/…/src \
Path for code ASM files
PATH_ASM = $(PATH_C)
Path for include C files
PATH_H =
…/…/inc
…/…/itf
C:OpenATToolsGCC4.0.1.0arm-elflib
/cygdrive/C/OpenAT/V400.b01/TgtGen/Add-ons/TCPIP/inc \
Path for include ASM files
PATH_I = $(PATH_H)
Absolute paths for Object files
PATH_EXT_OBJ = \
Root paths for Object files
PATH_ROOT_OBJ = \
Absolute paths for Library files
PATH_EXT_LIB = \
Root paths for Library files
PATH_ROOT_LIB = \
endif
Hello Bulat,
I don’t advise you to develop IP application with edlib for 2686. It is waste of time now, because there will be no final edlib libary. Wavecom changed to WIP, which has final TCP socket implementation and it works quite well.
Get the latest 4.10 OAT (WIP included) and develop for WIP, because the future is that.
Best Regards,
tom
Hello tomalex,
What if i already have written a program that uses the EDLIB from OPEN AT 3.02, can i use it on newer firmwares on newers Q2406B modules ?
Or, if not, can i downgrade the newer Q2406 modules ?
Thank you.
Answer for bruno…:
http://www.wavecom.com/modules/movie/scenes/forums/viewtopic.php?f=16&t=2239&p=8276#p8276
