I cant watch +CREG: 1
Hello everyone!!, im working on a GSM/GPRS project and i would like to read the unsolicited response ’ +CREG: 1’ and ‘+CGREG: 1’.
This is my code:
//attachment handler//
u8 initreg_SIM (void)
if (adl_atUnSoSubscribe("+CREG:",gms_register_handler)==OK)
TRACE (( 1, “[init_SIM]:+CREG: 1 subscribe OK” ));
if(adl_atUnSoSubscribe("+CREG: 0",gms_unregister_handler)==OK)
TRACE (( 1, “[init_SIM]:+CREG: 0 subscribe OK” ));
if(adl_atUnSoSubscribe("+CREG: 2",gms_unregister_handler)==OK)
TRACE (( 1, “[init_SIM]:+CREG: 2 subscribe OK” ));
return 1; //Primer paso de la inicializacion hecha.
else
TRACE (( 1, “[init_SIM]:+CREG: 2 subscribe ERROR” ));
else
TRACE (( 1, “[init_SIM]:+CREG: 0 subscribe ERROR” ));
else
TRACE (( 1, “[init_SIM]:+CREG: 1 subscribe ERROR” ));
return 0;
Later on, in the handlers…
bool gms_register_handler (adl_atUnsolicited_t *param)
if (GSM_ini==1 && GSM_reg==0) //Se debe registrar una sola vez.
GSM_reg=1;
TRACE (( 1, “[gms_register_handler]:SIM_REGISTRADO” ));
return TRUE;
bool gms_unregister_handler (adl_atUnsolicited_t *param)
if (GSM_ini==1 && GSM_reg==1)
TRACE (( 1, “[gms_unregister_handler]:SIM NO REGISTRADO.REINTENTADO…” ));
GSM_reg=0;
else
TRACE (( 1, “[gms_unregister_handler]:SIM NO REGISTRADO” ));
return TRUE;
When i run the apllication, it never go inside those handlers. But if y enter “AT+CREG?” the answer is “+CREG: 0,1” so i assume its registered!.
Can anyone help me?. Thanks!.
You need to post your code using the ‘Code’ tags to make it legible - see the ‘Code’ button to apply the ‘Code’ formatting…
Thanks!!, ill reply with this feature.
TRACE (( 1, "[init_SIM]:+CREG: 1 subscribe OK" ));
TRACE (( 1, "[init_SIM]:+CREG: 0 subscribe OK" ));
TRACE (( 1, "[init_SIM]:+CREG: 2 subscribe OK" ));
else
TRACE (( 1, "[init_SIM]:+CREG: 2 subscribe ERROR" ));
else
TRACE (( 1, "[init_SIM]:+CREG: 0 subscribe ERROR" ));
else
TRACE (( 1, "[init_SIM]:+CREG: 1 subscribe ERROR" ));
return 0;
Later on, in the handlers....nicool67
GSM_reg=1;
TRACE (( 1, "[gms_register_handler]:SIM_REGISTRADO" ));
return TRUE;
TRACE (( 1, "[gms_unregister_handler]:SIM NO REGISTRADO.REINTENTADO...." ));
GSM_reg=0;
else
TRACE (( 1, "[gms_unregister_handler]:SIM NO REGISTRADO" ));
return TRUE;
Do you really write your code like that - with no indentation at all :question: :open_mouth:
Note: don’t use TABs for indentation (their interpretation cannot be relied upon - especially on web forums) - use only spaces.
Well, actually i didint, but when i posted for some reason it appeared like that.
The important code in the hole aplicattion is this:
adl_simSubscribe(SimHandler,NULL); //First of all, i suscribed here
//in  SimHandler
case ADL_SIM_STATE_FULL_INIT: //I reached here without problems
//in an other part of the code
adl_atUnSoSubscribe("+CREG: 1",gms_register_handler)  // I need the +CREG: 1 response.
//in the handler
bool gms_register_handler (adl_atUnsolicited_t *param) //It never reaches here.
     GSM_reg=1;
return TRUE;
So, i`ve said i cant manage to get inside “gms_register_manager”. I need the +CREG: 1 response to know the SIM registration. Thanks for advance
Best Regards.
I think i solve it!, i change the orden of the code. I realized that the unsolicited response +CREG: 1 comes faster than the event ADL_SIM_STATE_FULL_INIT. So, now i check when both of conditions are true to know if im really registered.
Thank u so much.
Don’t forget that CREG status of “5” is also registered…
As I understand it, the ADL_SIM_STATE_FULL_INIT indicates that everything including phonebook initialisations is complete;
Phonebook initialisations can take quite a long time, and are not required for GSM registration - hence registration may occur before ADL_SIM_STATE_FULL_INIT.
In practice, you just have to assume that the events could occur in either order.
Also note what JasonDiplomat said about +CREG: 5…
