Roaming
With the Q24Pl and V657d, my embedded GPRS aplication works fine but when I try to use it in a diferent country I receive the +CREG:5 message but I
never receive +CGREG:5 and the GPRS is not working.
I tested the SIM card in my telephone and it works fine in voice and gprs data mode.
is there something that I should do on the module in order to activate or to force the registration for the roaming ???
Thank you,
Sladjan.
So +CGREG result do you receive?
Or what reply do you get to AT+CGREG? :question:
I do not know what my application receives because I am not in that new country but I am trying to use Windows RAS without my embedded application in order
to connect to internet for test and it does not work.
On AT+CREG? I get +CREG:2,5
but on AT+CGREG? I get +CGREG:2,0 and not :2,5 ???
Sladj.
Hello sladjan,
First of all you should check your operator’s GPRS roaming partners. ( the voice roaming does not always mean GPRS roaming )
After that you should select the specific operator manually. (AT+COPS)
Cheers,
tom
