Hi @jyijyi ,
How to use esim on the sierra EM9291 module?
Can you please help me check if it is enabled and how to validate it?
Arti
Hi @jyijyi ,
Arti
do you mean you already have an internal eSIM inside your EM9291 module?
Or you are testing a eSIM chipset connecting to the SIM slot 1 of EM9291?
By default the EM9291 supports esim right?
I need the steps to enable and use it.
Please note that not all EM9291 has internal eSIM inside…
if your module already has internal eSIM, have you switch to UIM:1 and check AT+CPIN?
How can I check if my module supports it?
if your module already has internal eSIM, have you switched to UIM:1 and check AT+CPIN?
AT!CUSTOM?
!CUSTOM:
GPSENABLE 0x01
GPSSEL 0x01
IMCONFIG 0x02
IPV6ENABLE 0x01
SIMLPM 0x01
USBSERIALENABLE 0x01
ICMPINTSRVDIS 0x01
SIMLPA 0x01
AT!UIMS?
!UIMS: 0
AT!UIMS=1
ERROR
you need to enable UIM2ENABLE in AT!CUSTOM?
yes,
I need steps to enable esim on the EM9291 sierra module and how to configure it?
Also I don’t know what was the issue earlier but I am getting this now:
at!custom?
!CUSTOM:
GPSENABLE 0x01
GPSSEL 0x01
IMCONFIG 0x02
IPV6ENABLE 0x01
UIM2ENABLE 0x01
SIMLPM 0x01
ICMPINTSRVDIS 0x01
SIMLPA 0x01
at!uims=1
AT+CPIN?
+CME ERROR: SIM not inserted
then it seems there is no eSIM inside
Hi @jyijyi
Do you have any documenation related to the usage of ESIM for EM9291.
see if this helps:
BTW, are you going to order another EM9291?
I am still not able to understand why my EM9291 doesn’t support esim?
How can I confirm it?
These are my command output:
at!uims=1
at!custom?
!CUSTOM:
GPSENABLE 0x01
GPSSEL 0x01
IMCONFIG 0x02
IPV6ENABLE 0x01
UIM2ENABLE 0x01
SIMLPM 0x01
ICMPINTSRVDIS 0x01
SIMLPA 0x01
AT!ENTERCND=“A710”
AT!CUSTOM=“UIM2ENABLE”,2
AT!RESET OK
AT+CPIN?
+CME ERROR: SIM busy
AT!ICCID? ERROR
AT!UIMS?
!UIMS: 1
OK AT!CUSTOM?
!CUSTOM:
GPSENABLE 0x01
GPSSEL 0x01
IMCONFIG 0x02
IPV6ENABLE 0x01
UIM2ENABLE 0x02
SIMLPM 0x01
ICMPINTSRVDIS 0x01
SIMLPA 0x01
AT!SKU?
!SKU: 1105097
The Technical datasheet states that
eSIM support is SKU-dependent.
How can I confirm this?
if it supports internal eSIM, it should show the following:
AT!ENTERCND="A710"
AT!CUSTOM="UIM2ENABLE",2
AT!RESET
AT!UIMS=1
AT+CCID
+CCID: ,89033023425121000000032777458112
AT+CIMI
ERROR
AT+CPIN?
Maybe you can try UIM2ENABLE=2
I tried your suggestion, here is my output:
AT!ENTERCND=“A710”
AT!RESET
AT!UIMS=1
AT+CCID
+CCID: ,89033023425121000000053200559598
AT+CIMI
ERROR
AT+CPIN?
hence it does support esim right?
yes, i think so…
there is EID shown
what is the next step?
How Can I use it?
see if this helps:
