eSIM - EM9291's second slot
I am trying to use my EM9291 as a dual sim with one slot as an eSIM. I am trying to send apdu messages with an lpac to save the profile onboard but it’s not working. I am using qmicli version 1.37 and modem firmware version 2.17
I also saw in the AT command reference document that the latest FW is 3.04 but on the sources page it only goes to 2.17.
Any advice? @jyijyi
FW 3.04 probably is referring to em91 module
So is eSIM supported?
I had trouble with LPA but I can get slot 2 as an eUICC - also I am using Ubuntu 20.04
what are the return of the following?
ati3
AT!entercnd="A710"
at!custom?
AT!uims?
at+cpin?
at+ccid
at+cimi
The 3.04 firmware is there under the PTCRB heading.
FYI Rel.8 includes modifications to the internal LPA meaning you will be able to communicate via LPAd such as LPAC. Rel.8 is 03.04 FW which is on the source.
@blackbow7 got it, I was using the 2.17 firmware under Generic - I will use the correct one and share results
**I am still having issues, these are the outputs to those commands:
ati3**
Model: EM9291
Revision: SWIX65C_03.04.10.01 00b8ca jenkins 2025/06/18 05:56:16
IMEI: 358186652142931
IMEI SV: 11
FSN: 833445509504B1
+GCAP: +CGSM
AT!entercnd=“A710”
at!custom?
!CUSTOM:
         GPSENABLE 0x01
         GPSSEL 0x01
         IMCONFIG 0x02
         IPV6ENABLE 0x01
         UIM2ENABLE 0x02
         SIMLPM 0x01
         USBSERIALENABLE 0x01
         ICMPINTSRVDIS 0x01
         SIMLPA 0x01
AT!uims?
!UIMS: 1
at+cpin?
+CME ERROR: SIM busy
at+ccid
+CCID: ,89033023425121000000026672210309
at+cimi
ERROR
and this is my slot and card status
sudo qmicli -d /dev/cdc-wdm0 --device-open-proxy --uim-get-slot-status
[/dev/cdc-wdm0] Successfully got slots status
[/dev/cdc-wdm0] 2 physical slots found:
Physical slot 1:
 Card status: present
 Slot status: inactive
       ICCID: 89148000004222428149
    Protocol: uicc
    Num apps: 0
    Is eUICC: no
Physical slot 2:
 Slot status: active
Logical slot: 1
       ICCID: unknown
    Protocol: uicc
    Num apps: 0
    Is eUICC: yes
         EID: 89033023425121000000026672210309
[2025/09/23-15:00:27] nsd25001(edit ~/.site): nsd_user@dcs: : ~
Purpose: feature/v2.0.31-patches/orin:
sudo qmicli -d /dev/cdc-wdm0 --device-open-proxy --uim-get-card-status
[/dev/cdc-wdm0] Successfully got card status
Provisioning applications:
Primary GW: session doesn’t exist
Primary 1X: session doesn’t exist
Secondary GW: session doesn’t exist
Secondary 1X: session doesn’t exist
Slot [1]:
Card state: ‘present’
UPIN state: ‘not-initialized’
UPIN retries: ‘0’
UPUK retries: ‘0’
Slot [2]:
Card state: ‘absent’
UPIN retries: ‘0’
UPUK retries: ‘0’
you can connect to Windows and see if you can see the “manage esim profiles” option
I do not have windows on this device, I am forced to exclusively use Linux
you might need to contact distributor to get an application note “2174369 Thales LPA SDK r1.pdf” on this eSIM implementation
This document describes how to use Thales’ Linux host-based LPA SDK to manage eSIM profiles over the EM9 module from Linux host machine.
