I’ve fumbled through getting this modem on, present in the system, and registered on a cell network.
Now I have no clue how to get wwan0 an IP. I’ve followed the few guides on here and else where and dhclient or the likes just times out on discovery or just immediately exits and the interface still doesn’t have an IP.
I might have broken something, as I originally wanted to use ECM mode and an ethernet bridge to give a router behind it the IP from the cellular ISP. I’ve given up on that as I have no idea what I’m doing, so I’ve gone back to trying to get raw_ip on qmi working.
# mmcli -m 0
General | path: /org/freedesktop/ModemManager1/Modem/0
| device id: xxxxxxxxx
Hardware | manufacturer: Sierra Wireless, Incorporated
| model: EM7565
| firmware revision: SWI9X50C_01.14.22.00 ba8ef1 jenkins 2022/11/11 09:59:48
| carrier config: default
| h/w revision: 1.5
| supported: gsm-umts, lte
| current: gsm-umts, lte
| equipment id: xxxxxxxxxx
System | device: /sys/devices/pci0000:00/0000:00:15.0/usb2/2-6
| drivers: qmi_wwan, qcserial
| plugin: sierra
| primary port: cdc-wdm0
| ports: cdc-wdm0 (qmi), ttyUSB0 (qcdm), ttyUSB1 (gps),
| ttyUSB2 (at), wwan0 (net)
Numbers | own: 1xxxxxxxxxx
Status | lock: sim-pin2
| unlock retries: sim-pin (3), sim-puk (10), sim-pin2 (3), sim-puk2 (10)
| state: registered
| power state: on
| access tech: lte
| signal quality: 75% (recent)
Modes | supported: allowed: 3g; preferred: none
| allowed: 4g; preferred: none
| allowed: 3g, 4g; preferred: 4g
| allowed: 3g, 4g; preferred: 3g
| current: allowed: 3g, 4g; preferred: 4g
Bands | supported: utran-1, utran-4, utran-6, utran-5, utran-8, utran-9,
| utran-2, eutran-1, eutran-2, eutran-3, eutran-4, eutran-5, eutran-7,
| eutran-8, eutran-9, eutran-12, eutran-13, eutran-18, eutran-19,
| eutran-20, eutran-26, eutran-28, eutran-29, eutran-30, eutran-32,
| eutran-41, eutran-46, eutran-66, utran-19
| current: utran-1, utran-4, utran-6, utran-5, utran-8, utran-9,
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: xxxxxxxxxx
| enabled locks: fixed-dialing
| operator id: 310410
| operator name: AT&T
| registration: home
| packet service state: attached
3GPP EPS | ue mode of operation: csps-2
| initial bearer path: /org/freedesktop/ModemManager1/Bearer/0
| initial bearer apn: nxtgenphone
| initial bearer ip type: ipv4v6
SIM | primary sim path: /org/freedesktop/ModemManager1/SIM/0
| sim slot paths: slot 1: /org/freedesktop/ModemManager1/SIM/0 (active)
| slot 2: none
So after all the problems, I started over with qmicli.
# qmicli -p -d /dev/cdc-wdm0 --dms-get-operating-mode
[/dev/cdc-wdm0] Operating mode retrieved:
Mode: 'online'
HW restricted: 'no'
# ip link set wwan0 down
# echo 'Y' | sudo tee /sys/class/net/wwan0/qmi/raw_ip
Y
# ip link set wwan0 up
# qmicli -p -d /dev/cdc-wdm0 --wda-get-data-format
[/dev/cdc-wdm0] Successfully got data format
QoS flow header: no
Link layer protocol: 'raw-ip'
Uplink data aggregation protocol: 'disabled'
Downlink data aggregation protocol: 'disabled'
NDP signature: '0'
Downlink data aggregation max datagrams: '0'
Downlink data aggregation max size: '0'
# qmicli -p -d /dev/cdc-wdm0 --device-open-net='net-raw-ip|net-no-qos-header' --wds-start-network="apn='nxtgenphone',ip-type=4" --client-no-release-cid
error: couldn't open the QmiDevice: Transaction timed out
# ip link show wwan0
6: wwan0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN mode DEFAULT group default qlen 1000
link/none
# qmicli -p -d /dev/cdc-wdm0 --nas-get-signal-strength
[/dev/cdc-wdm0] Successfully got signal strength
Current:
Network 'lte': '-68 dBm'
RSSI:
ECIO:
Network 'lte': '-2.5 dBm'
IO: '-106 dBm'
SINR (8): '9.0 dB'
RSRQ:
Network 'lte': '-12 dB'
SNR:
Network 'lte': '13.6 dB'
RSRP:
Network 'lte': '-99 dBm'
I thought maybe ModemManager was messing something up, so I rebooted with it disabled.
Got a little further than before, but no luck getting an IP.
# ip link set wwx02360d4c2e4c up
# qmicli -d /dev/cdc-wdm0 --device-open-net='net-raw-ip|net-no-qos-header' --wds-start-network="apn='nxtgenphone',ip-type=4" --client-no-release-cid
[/dev/cdc-wdm0] Network started
Packet data handle: '4251282640'
[/dev/cdc-wdm0] Client ID not released:
Service: 'wds'
CID: '18'
# udhcpc -q -f -i wwx02360d4c2e4c
udhcpc: started, v1.35.0
udhcpc: broadcasting discover
Just stuck on discover.
What am I doing wrong here?
I would really appreciate someones help getting up to speed on this.
Also I saw theres a /sys/class/net/wwx02360d4c2e4c/qmi/pass_through for qmi. Does this mean I can give the ISP IP to a device behind this modem? I can’t find anything online about a pass_through mode
