How to put file to vsftpd server using FTPS sample.
I want to put file to vsftpd server using FTPS sample of following URL.
developer.sierrawireless.com/Res … ample.aspx
data.txt file is created in the vsftpd server, but data of the contents are garbled, and the file size is 84byte.
If I specify the WIP_SSL_NEVER to parameters of wip_SSLInitOpts(), I can send the data.txt to the IIS server.
But, when I sent the data.txt to the vsftpd server, it was not send.
1.What is the cause that data cannot be sent to a vsftpd server?
2.Are there anyone who transmitted the file to the server of vsftpd using the FTPS sample?
My development environment is following.
Communication unit : AX8084NE
LSI of communication unit : SL8084T
Server OS : Fedora9
FTP mode : passive
