How could I check antenna if the connection normal in EM9191?
I already use at!gstatus? at!nrinfo? , but I can’t check the antenna connection.
did you see some antenna info like the following in AT!GSTATUS?
PCC RxM RSSI: -31 PCC RxM RSRP: -61
PCC RxD RSSI: --- PCC RxD RSRP: ---
SCC1 RxM RSSI: -58 SCC1 RxM RSRP: -75
SCC1 RxD RSSI: -59 SCC1 RxD RSRP: -76
SCC1 RxM1 RSSI: --- SCC1 RxM1 RSRP: ---
SCC1 RxD1 RSSI: --- SCC1 RxD1 RSRP: ---
Hi @jyijyi ,
Yes, I can but I want to test my 4 antennas connection
Could I use !DAGFTMRXAGC to check it?
didn’t it already show 4 antennas?
RxM ↔ Main
RxD ↔ Aux
RxM1 ↔ MIMO1
RxD1 ↔ MIMO2
how about setting it to LTE only with AT!SELRAT command?
Hi @jyijyi ,
You mean that I use AT!SELRAT to force on LTE?
yes, you can try that
Hi @jyijyi ,
BTW If I connect to N1 or B1, Does it possible only show RxM and RxD’s RSSI ?
have you tried that?
