EM9191 in NR mode not reporting SNR in NRINFO
With an established connection this is a typical response to AT!NRINFO
at!nrinfo? !NRINFO:
Connectivity Mode: SA
NR5G Cell ID: 0
NR5G band: n78 NR5G Carrier ID: 0
NR5G dl bw: 40 MHz NR5G ul bw: 40 MHz
NR5G Tx Power: 20 NR5G Tx chan: 636666
NR5G Rx chan: 636666
NR5G dl MIMO: 0 NR5G ul MIMO: 1
NR5G(sub6) RxM RSSI (dBm): -26.5 NR5G(sub6) RxD RSSI (dBm): -31.4
NR5G(sub6) RxM1 RSSI (dBm): -21.5 NR5G(sub6) RxD1 RSSI (dBm): -28.6
NR5G RSRP (dBm): β€” NR5G RSRQ (dB): β€”
NR5G SINR (dB): β€”
Is there some configuration to turn on reporting for SNR and or RSRP, RSRQ ?
Probably you need to wait for the next FW release 03.10.xx.xx to fix this
not only SINR, when you register at SA mode, you cann’t get RSRP RSRQ either. :frowning:
you need to wait for the next FW release 03.10.07.00 to fix this
Hi Jyi
Any idea when 03.10.07 will be available?
Best Regards,
Greg
you can contact distributor to get it
