How to extract/implement the configuration of a GL8200
I am trying to configure a GL8200 modem to look like a working GL8200.
Despite several tests and a similar configuration, it does not communicate.
Do you know how to extract a configuration from one modem and inject it into another modem?
Model No: GL8200
Manufacturer: Sierra Wireless
Software Version: Revision : SIERRA RGL8200.5.5.22.0.201603171544.x6250_3
Functional modem configuration :
IMEI: 014532000060836
IMSI:204080806552687
Clock: 04/01/01,00:04:05-01
SIM Status: SIM is ready
APN: matooma.m2m
Signal Strength: -77 dbm
Signal Condition: Good
Carrier: 20801
Registration Status: Roaming
Connected Status: Connected
IP Address: “10.177.205.104”
Attached Status: Attached
Device Functionality: Full
Station Class B
SMS Mode: Text
Port Speed: 115200
Configuration of the modem I am trying to communicate with:
Model No: GL8200
Software Version: Revision : SIERRA RGL8200.5.5.25.0.201804161340.x6250_2
IMEI: 014532000182655
Clock: 14/01/01,00:19:01-01
APN: matooma.m2m
Carrier: 20801
IP Address:
Station Class B
SMS Mode: Text
Port Speed: 115200
Your help would be welcome, I’m starting to run out of ideas here.
Thanks a lot,
Best Regards
Hi @j.tissier
The GL8200 does not support extracting configuration from one modem and injecting it into another modem.
Are you using the same GL8200 firmware version on both modems?
Please download the latest firmware and retry.
Firmware GL8200
Could you describe in more detail the issue on GL8200?
Please share with me the AT commands log file what you want to do step by step i.e. 1, 2, 3, 4, etc. I will help you to analyze the issue.
I have just upgraded my GL8200 modem to 5.26 and I can no longer enter an AT command.
Before this the problem was that when doing an AT+CGACT? I had the result 1.0
So I was doing an AT+CGACT=1.1 but a short time later he picks up the network again.
For information I have another GL8200 in 5.22 which connects at the first time without configuration.
Is it possible to downgrade from version 5.24 or 5.25 to version 5.22?
Sincerely
Hi j.tissier,
Yes, it is.
How do I reset a GL8200 modem? I can no longer enter an AT command since the 5.26 update.
Thank you in advance
Best Regards
Hi j.tissier,
Resetting the GL8200 could be done by simply unplugging and then re-plugging the power supply (VIN-VBUS). In addition to Sierra Wireless’ reliable recovery mechanisms, it is highly recommended that the ability for a cycle to reboot the modem be included in the design in case the modem becomes blocked and stops responding to reset commands.
Hi Donald,
I just tried to downgrade the GL8200 modem (version 5.25) to version 5.22 and I get an error :
Device synchronized.
Details> Injecting RPSI
Details> Injecting EBL
Details> Boot-loader is active
Details> EBL version: XMM6260_1327.100_M1S1 1327…100
Details> Boot mode is: BB
Using: Normal CRC, Writing all blocks , Skip data CRC
Details> Package length is 2048 - protocol: 1.16
Details> Baud rate set to 460800
Details> Get flash id.
Target error[0]: ‘storage_hw_setup’ Line: 433 File: storage_nand.c
Target error[1]: ‘ERROR_CODE: 0x00000001’ Line: 238 File: storage_nand.c
Target error[2]: ‘Handling package type: ReqFlashId failed.’ Line: 577 File: flashlogic_app.c
Hi @j.tissier
It might depend on the age of your module, the unit was initially designed with two qualified memories as you would expect for good design practice to cater for EOL’s.
Please refer to HL8548-G downgrade firmware - #4 by rcolet
