On FX30 (LTE-M version), we use custom Yocto/Legato software based on R14.
Since the latest FX30 are in R15, I try to downgrade to R14 before installing our application.
On windows I do :
fdt2.exe -f FX30_WP77xx_full_R14.1.1.002-generic-SWI9X06Y_02.36.06.00.cwe
do you mean you have some FX30 module that can downgrade from R15 .1 to R14?
And you now have some other FX30 modules that cannot downgrade from R15.1 to R14?
It’s annoying if we can’t downgrade. We use about ten modems a year and we can’t modify our Yocto/Legato every time the firmware that comes with the modem is updated…
originally i guess they are having different flash model in AT!BSINFO to explain the issue.
But now your observation shows that they are having same flash, i don’t know what is the difference makes the issue, seems everything is the same
I checked the ati8 of your dowodile, the yocto and rootfs built date are in year 2024, but the release note of r14.1 shows it should be built in year 2021, so i wonder if you have downgraded the correct one
