I use CMW500 to emulate Verizon network, parameter as SID=4, NID=8, channel=384, band = BC0.
I input CMW500 test card in device with minicard MC 7354, and connect the device to CMW500.
But the device cant camp to CMW500 emulater network.
If I change the network in CMW500 to WCDMA, the device can camp to CMW500 WCDMA network.
What I miss for CDMA network?
Have you configured the deice to be used with Verizon?
Default the module is configured for AT&T. Check with
at!priid?
at!gobiimpref?
I use MC7354 in a device like tablet PC.
And every AT extensional copmmand return ERROR.
Do I need a dev kit to be able to successfully use the following AT commands?
at!priid
at!gobiimpref
BTW, I can confirm current configuration is for AT&T and working fine.
What can I do to have CDMA working on it?
You might have to run AT!ENTERCND=“A710” to run these commands.
Then you use the previous mentioned commands to figure out which pri to switch to. Use AT!GOBIIMPREF command to do the actual switch. I suggest you take a look at the AT command guide:
http://developer.sierrawireless.com/Resources/Resources/AirPrime/Minicard/4114486_AirPrime_MC73XX-8805_AT_Command_Reference.aspx
I will try it.
And I have downlaoded the at command, but I thought I should have dev kit first to setcnd.
I don’t know the minicard have default password.
AT!GOBIIMPREF?
!GOBIIMPREF:
preferred fw version: 05.05.16.02
preferred carrier name: ATT
preferred config name: ATT_005.010_000
current fw version: 05.05.16.02
current carrier name: ATT
current config name: ATT_005.010_000
AT!PRIID?
PRI Part Number: 9903211
Revision: 05.03
Carrier PRI: 9999999_9902196_SWI9X15C_05.05.16.02_00_ATT_005.010_000
Carrier PRI: 9999999_9902574_SWI9X15C_05.05.22.00_00_GENNA-UMTS_005.009_000
Carrier PRI: 9999999_9902350_SWI9X15C_05.05.22.00_00_SPRINT_005.011_000
Carrier PRI: 9999999_9902266_SWI9X15C_05.05.16.02_00_VZW_005.012_002
I think I should use 05.05.16.02_00_VZW_005.012_002 to set AT!GOBIIMPREF
This should work I think
AT!ENTERCND=“A710”
AT!GOBIIMPREF=“05.05.16.02”,“VZW”,“VZW_005.012_002”
AT!RESET
