larry1
1
I found that there is no PID in MBPL usb source code.
In qcserial.c
I added
{USB_DEVICE(0x1199, 0x9114)},
In qmi_wwan.c
what should I add ?
{QMI_FIXED_INTF(0x1199, 0x9114, 8)},
or
{QMI_QUIRK_SET_DTR(0x1199, 0x9114, 8)},
or
{QMI_GOBI_DEVICE(0x1199, 0x9114)},
jyijyi
2
this module does not have RMNET, so not using qmi_wwan.c:
at!usbcomp=?
!USBCOMP:
AT!USBCOMP=<Config Index>,<Config Type>,<Interface bitmask>
<Config Index> - configuration index to which the composition applies, should be 1
<Config Type> - 1:Generic
- 2:Network Interface
<Interface bitmask> -
00000001-Log DIAG
00000008-AT (This interface cannot be disabled)
00000010-AT_PPP
00001000-RNDIS
00002000-ECM
You can try PPP dial-up by “AT!USBCOMP=1,1,19”
larry1
3
Hi @jyijyi ,
Thanks for your reply.
How do I connect to network?
Could I use rndis or ECM?
And what kind of AT port is it like ttyACM0~2 ?
jyijyi
4
do you have the AT port now? (e.g. /dev/ttyACM0 or /dev/ttyACM2)
you can use wvdial in linux for ppp dial up
[ 38.915482] usb 3-2.1: Product: RC7120
[ 38.915483] usb 3-2.1: Manufacturer: Sierra Wireless, Incorporated
[ 38.915484] usb 3-2.1: SerialNumber: 359112220012345
[ 39.326969] usbcore: registered new interface driver cdc_ether
[ 39.391317] rndis_host 3-2.1:1.0 eth0: register 'rndis_host' at usb-0000:03:00.0-2.1, RNDIS device, 20:89:84:6a:96:ab
[ 39.395386] cdc_acm 3-2.1:1.2: ttyACM0: USB ACM device
[ 39.404353] cdc_acm 3-2.1:1.4: ttyACM1: USB ACM device
[ 39.414947] cdc_acm 3-2.1:1.6: ttyACM2: USB ACM device
[ 39.416828] usbcore: registered new interface driver cdc_acm
larry1
5
Hi @jyijyi ,
Yes I found the ttyACM0,
Could you give me a sample to connect network?
jyijyi
6
you can see this example:
PPP_example.docx (16.8 KB)
larry1
7
Hi @jyijyi ,
If I +cpin? got “CME error 303” what does it mean?
jyijyi
8
see here:
seems your SIM card has problem:
at+cpin?
+CPIN: READY
ati3
Model: RC7120
Revision: SWI216C_01.02.08.00 2024/02/29 15:43:11
SVN: 01
IMEI: 359112220012345
FSN:
TS.25: 2024.01.01
+GCAP: +CGSM
larry1
9
Hi @jyijyi ,
ati3
Model: RC7120
Revision: SWI216C_01.02.06.00 2023/12/08 15:29:19
SVN: 01
IMEI: 359112220002612
FSN: EU3516021503HC
TS.25: 2023.10.23
+GCAP: +CGSM
Should I update FW ?
jyijyi
10
i don’t know, you can try
larry1
11
Hi @jyijyi ,
Could I use mmcli to control RC7120 ?
jyijyi
12
Is mmcli using ppp dial up?
larry1
13
Hi @jyijyi ,
Yes, use ppp dial and got some module information .
Could I use mmcli to query and connect to network?
jyijyi
14
I never use mmcli, but if it uses ppp dial up, it should work as wvdial
This is 3rd party application, so probably you need to make some test
