I following MBPL to modify Kernel 3.18 qmi_wwan.c usb_wwan.c and qcserial.c in openwert but I got error.
qmi_wwan: probe of 1-1:1.8 failed with error -1
Please help me to solve it.
Thanks.
Thanks.
According to the “Software_Integration_and_Development_Guide_for_Linux_USB_Platforms_R24.pdf”
You might need to use the old Gobi driver:
Hi @jyijyi ,
Do you have porting guide ?
Hi @jyijyi ,
I have a question about what kernel config should I enable or disable ?
Should I disable qmi-wwan ?
I usb support what should enable or disable?
CONFIG_PACKAGE_kmod-usb-net
CONFIG_PACKAGE_kmod-usb-net-qmi-wwan
CONFIG_PACKAGE_kmod-usb-serial
CONFIG_PACKAGE_kmod-usb-serial-qualcomm
CONFIG_PACKAGE_kmod-usb-wdm
CONFIG_PACKAGE_kmod-usb-core
CONFIG_PACKAGE_kmod-usb-net-sierrawireless
CONFIG_PACKAGE_kmod-usb-serial-wwan
Hi @jyijyi ,
Thanks for your reply, but I have another question about gobinet
Should I compile all usbnet_x_x_xx.c ?
you can just change the toolchain location according to your environment and then build it.
Here is an example I compiled the gobiNet driver with WP76 toolchain by “sudo make WP”
Makefile (2.8 KB)
i remember the makefile and the #ifdef inside the source code will handle those things.
probably you just enter “sudo make” and it will be OK
Hi @jyijyi ,
Thanks for your reply but I use openwrt and my makefile
include $(TOPDIR)/rules.mk
include $(INCLUDE_DIR)/kernel.mk
PKG_NAME:=gobinet
PKG_RELEASE:=1
include $(INCLUDE_DIR)/package.mk
define KernelPackage/gobinet
SUBMENU:=Other modules
TITLE:=Gobinet for WP7702
DEPENDS:=+kmod-usb-core kmod-usb-net
FILES:=$(PKG_BUILD_DIR)/gobinet.ko
AUTOLOAD:=$(call AutoLoad,50,gobinet)
KCONFIG:=
endef
define KernelPackage/gobinet/description
Kernel module driver for Sierra Wireless WP7702
endef
EXTRA_KCONFIG:= \
CONFIG_GOBINET=m
EXTRA_CFLAGS:= \
$(patsubst CONFIG_%, -DCONFIG_%=1, $(patsubst %=m,%,$(filter %=m,$(EXTRA_KCONFIG)))) \
$(patsubst CONFIG_%, -DCONFIG_%=1, $(patsubst %=y,%,$(filter %=y,$(EXTRA_KCONFIG)))) \
MAKE_OPTS:= \
$(KERNEL_MAKE_FLAGS) \
SUBDIRS="$(PKG_BUILD_DIR)" \
EXTRA_CFLAGS="$(EXTRA_CFLAGS)" \
$(EXTRA_KCONFIG)
define Build/Compile
$(MAKE) -C "$(LINUX_DIR)" \
$(MAKE_OPTS) \
modules
endef
$(eval $(call KernelPackage,gobinet))
And I got error.
I fixed it sorry
i tried in ubuntu 12 with kernel 3.11, no problem is found
owner@ubuntu:~/QMI/S2.32N2.51/GobiNet$ uname -r
3.11.0-15-generic
owner@ubuntu:~/QMI/S2.32N2.51/GobiNet$ sudo make clean
rm -rf *.o *~ core .depend .*.cmd *.ko *.mod.c .tmp_versions Module.* modules.order
make -C /lib/modules/3.11.0-15-generic/build M=/home/owner/QMI/S2.32N2.51/GobiNet modules
make[1]: Entering directory `/usr/src/linux-headers-3.11.0-15-generic'
CC [M] /home/owner/QMI/S2.32N2.51/GobiNet/GobiUSBNet.o
CC [M] /home/owner/QMI/S2.32N2.51/GobiNet/QMIDevice.o
CC [M] /home/owner/QMI/S2.32N2.51/GobiNet/QMI.o
CC [M] /home/owner/QMI/S2.32N2.51/GobiNet/usbnet_2_6_32.o
CC [M] /home/owner/QMI/S2.32N2.51/GobiNet/usbnet_3_0_6.o
CC [M] /home/owner/QMI/S2.32N2.51/GobiNet/usbnet_2_6_35.o
CC [M] /home/owner/QMI/S2.32N2.51/GobiNet/usbnet_3_10_21.o
CC [M] /home/owner/QMI/S2.32N2.51/GobiNet/usbnet_3_12_xx.o
CC [M] /home/owner/QMI/S2.32N2.51/GobiNet/usbnet_4_4_xx.o
LD [M] /home/owner/QMI/S2.32N2.51/GobiNet/GobiNet.o
Building modules, stage 2.
MODPOST 1 modules
CC /home/owner/QMI/S2.32N2.51/GobiNet/GobiNet.mod.o
LD [M] /home/owner/QMI/S2.32N2.51/GobiNet/GobiNet.ko
make[1]: Leaving directory `/usr/src/linux-headers-3.11.0-15-generic'
Hi @jyijyi ,
I can compiled gobiserial.ko and gobinet.ko, but I got another question in GobiSerial
GobiSerial 1-1:1.0: no of_node; not parsing pinctrl DT
no idea, i have never seen this message before
can you communicate via /dev/ttyUSB2 which should be the AT command port?
Hi @jyijyi ,
Yes I can access /dev/ttyUSB2 and send at command.
I have no idea about this problem, but never see this log after reboot device.
