How do I setup the data connection on Verizon network without specifying the APN?
If you are on the Verizon network then you need to be using the Verizon firmware/PRI file and that comes with APN’s populated as per Verizon’s requirements.
Verizon is using a different APN for static IP SIM and dynamic IP SIM. Please confirm if this can also be handled automatically by the latest firmware?
