How could I change UART baud rate which is in the mangOH-yellow external card ?
Do you mean UART1?
What do you set for AT!MAPUART?
are you using it in AT command mode? If yes, you might try AT+IPR to change baud rate
I set at!mapuart=17,1
You mean like it “AT+IPR=9600” ?
Then this is in data mode
You can try the following for setting baud rate to 115200:
stty -F /dev/ttyHS0 raw 115200 -crtscts
microcom /dev/ttyHS0 -s 115200
Hi @jyijyi ,
Thanks for your reply.
I want to know if I only want to set baud rate “stty -F /dev/ttyHS0 raw 9600” ?
How to I save the setting?
you don’t need to save the setting
just set the baud rate when you open the port
Hi @jyijyi ,
But I want to save the setting , because I sometimes will reboot.
but after reset, you still need to type those commands to open the port, right?
