I am using the HL7812 IoT module in the HL78xx Development Kit but I am unable to force it into a low power mode using the +KSLEEP command. I have tried setting the module up in both the PSM Use Case and the eDRX Use Case outlined in the HL7800 Low Power Mode Application Note but I am not seeing the current consumption drop at all to indicate sleep. Are there other conditions that are required to enter sleep or hibernate?
I am measuring the global current consumed by the module (baseband + rf) as per the HL78xx Development Kit User Guide i.e. measuring the current through header CN804.
AT+KSLEEP=1,1,0
AT+CPSMS=1,“00100001”,“00001111” // TAU = 1hr, active = 30 seconds
And that’s all I am doing at the moment. During PSM active time registration status is +CEREG: 1, during TAU time registration status is +CEREG: 4. As far as I understand this is correct.
I have changed the order of the AT commands as you suggested and the WAKE-UP switch is off. I have noticed the FAST_SHD LED is continuously illuminated even though the button is not being pressed.
Result is the same. I am measuring ~14mA when the module should be in lite-hibernate mode.
HL7812 has not been officially sold yet and there is no official firmware on Sierra source page. I don’t know if the LPM feature worked well on this product. Could you please contact the supplier of this product for the info?
