Hi, i have no background with using this module and with AT commands. I am following some tutorials but i can’t connect my HL7812 to the network. When i turn on the module and i put the command AT+CEREG? the answer is “+CEREG: 1,3” so i try to do a manual registration with the following commands:
I am using my phone SIM, the operator is windtre, an italian company. Is the SIM able to work with this module?
What does it mean CME error: 31?
I have a lot of doubts but for now can you answer to these two questions?
I change APN, then i did the same command sequence of before (at+cops=?..) and after this sequence if i put at+cereg? command it answer with +cereg=1,5. I think i made it right?
