HL7810 becomes unresponsive
We have a serious problem using an HL7810 from an ESP32
We use AT+KHTTPGET to make a series http calls at various times
The presence of the SIM is checked periodically using AT+CCID
After a variable period of time the modem becomes unresponsive, i.e AT Commands are no longer responded to
I am unable to discern what conditions cause the problem
Restarting the esp32 has no effect - the only way I can recover the modem is to disconnect and reconnect the power.
The firmware version is HL7810.5.4.12.2
Is problem only in +khttpget?
How about +ktcp connection?
Btw, did you also try latest firmware?
https://source.sierrawireless.com/resources/airprime/software/hl781x-and-hl7845-firmware/hl781x-and-hl7845-firmware/
I am not sure if the problem is only with KHTTPGET as it is difficult to track down what is causing the issue, but I suspect it is.
Can you direct me to some instructions on how to update the firmware ?
You can run the exe in windows
https://source.sierrawireless.com/resources/airprime/software/hl781x-and-hl7845-firmware/hl781x-and-hl7845-release-4,-d-,2/
The modem is not connected to a windows machine - it is integrated into a board and controlled from an esp32 microcontroller
Did you try AVMS FOTA upgrade?
http://doc.airvantage.net/fota/howto/gettingstarted/
